Old 04-23-2008   #1
eagle talon guy
eagle talon guy's Avatar
Send a message via AIM to eagle talon guy
Question Unusual idle after clutch install
I recently replaced my clutch in my '93 Talon TSI. After we got it put together, it idled weird. It sounds like it is cammed. The needle on my boost gauge "shakes" a lot around 10 psi of vacuum. It's weird because it runs great, it's just weird when idling. I don't know what could cause this, but it's not normal, and i would really appreciate any advice given.
If there are any questions that would help you diagnose it, please ask and i will try my best to answer.
I will try to post a video soon.
Thanks
-Michael
(^^very old pic!)
6 Bolt build in progress
eagle talon guy is offline   Reply With Quote
Old 04-23-2008   #2
sleepy2lazy
sleepy2lazy's Avatar
Re: Unusual idle after clutch install
Try reading that. Those could be some of your problems.
http://members.shaw.ca/costall/1000Q...otidleverywell
sleepy2lazy is offline   Reply With Quote
Old 04-23-2008   #3
4g63tcrazy
is Nashty
4g63tcrazy's Avatar
Drives: Cyborg from Japan
Maybe a vac leak? If your talking about 10 vac on a aftermarket boost gauge then you for sure have a vacuum leak. Maybe even the gauge it's self.
-1990 Mitsubishi Cyborg 4WD-
Old 04-23-2008   #4
First place to start will be to double-triple check everything you removed while doing the clutch such as the intake, intercooler pipes, BOV, etc.
Old 04-23-2008   #5
Do a boost leak test!
Old 04-24-2008   #6
eagle talon guy
What is the easiest way to do that?
My friend told me to like tape off the pipe that goes down to the intercooler and stick an air compresser sprayer hose thing in it and listen for leaks. Is that the best way?
-Michael
(^^very old pic!)
Old 04-24-2008   #7
Make a boost leak tester with a piece of PVC and a bike tire valve stem. Search around here for more info on that
Old 04-24-2008   #8
No. You can build a pipe that clamps to the turbo inlet (must be air-tight) that has a valve stem on it, then you can use a air compressor to pressurize the system. If you don't want to make one most the local shops probably have one and would be willing to test your car for a small cost. Have you gone over everything you removed already to make sure all clamps are tight?
Old 04-24-2008   #9
brando
Drives: gutlass
did you get the flywheel resurfaced when you did the clutch. its just an idea but maybe your flywheel is a little out of balance and its only picking it up at low rpm. again its just an idea.
but it does sound like a vacume leak of some sort
Old 04-25-2008   #10
eagle talon guy
No, I didn't. I needed to get it together and running ASAP. If/when I put in a new clutch, I plan to resurface it though.
-Michael
(^^very old pic!)
