Old 04-27-2008   #1
Fidanza short-shifter (Evo VIII/IX)
First of all, thanks to Scheides for opening up his garage for me to work on my car and lending a hand with the install.
Great price, good quality, PITA install, and they really need to include install instructions! All said and done the shifter feels great, but the installation didn't exactly go smoothly. I got the kit on sale from Modern Automotive Performance for $59 which I think is a great deal since thats $20 off their regular price.
http://www.maperformance.com/store/p...cat=977&page=1
The kit included aluminum shifter base bushings which were very good quality and fit perfect. The kit also included 2 new white plastic bushings for the balls that attach to the shift cables, but they were really poor quality so I highly recommend reusing the stock ones (used a flathead screw driver to pry them off the stock shifter). I also had to buy a new upper pivot ball bushing from the Mitsu dealership for $14 since I didn't want to cut my stock shifter in half. I used heavy-duty marine grease on the pivot ball and the the shift cable balls.
The short-shifter comes with a removable counter-weight which was nice and really helps the shifts feel very smooth. The pivot ball is adjustable and has 2 settings. On the less aggressive setting the shifts are a bit shorter and the knob sits higher than stock (I was not impressed with this setting). I tried the less aggressive setting first because the more aggressive setting can not be used unless you hack up the plastic shifter base some which I did not want to do. I almost pulled the shifter out and returned to stock but I decided to stop being a pussy and just "clearance" the shifter base with a RotoZip. Fast forward a bit after everything was clearanced (with plastic chips and shavings all over the interior of my car and wreaking of burnt plastic) the shifter feels great on the aggressive setting. I am closer to my goal of getting my shifter to feel like the one in my S2000 (stock shifter w/countersunk knob). The shifts are now tight and precise. The throws are definitely shorter and the knob sits a bit lower than stock, but I can still shift with a 20oz bottle in the cup holder.
