Old 05-21-2008   #1
iceminion
iceminion's Avatar
experienced engine builders only.
Ok, last night I spun a rod bearing.
This was Bills engine, he works at MAP, he does not build engines for customers, I in no way believe that his craftsmanship was in any way responsible for the failure. 2.3L eagle/mahle (9.5:1) ~500 miles on engine.
I am 1/2 qt overfilled with oil, been that way for a couple weeks. I have no oil leaks.
Did a high revving launch (first time on this engine)
The engine makes a terrible noise, and there are small golden flakes in the oil.
The car is running on keydiver chip (for the 780cc's)
I have been running the car at 11-12psi because of the high compression ratio.
Shell 92 octane.
I think I have listed all the important factors here. what do you think? if it is just a rod bearing, can I just replace it?
what are the odds that I dont have to pull the crank?
Thanks
building a 3000GT AWD Turbo.
