Old 05-31-2008   #1
green hornet
Angry huge clutch issue need a little help
ok last sunday my starter plate came un-bolted "on my 1990 laser rs" so i took the tranny off along with every thing else "clutch, fly-wheel etc." bolted the plate back up, and put every thing back on, all torqed to spec, now my car will not go into gear at all, i pulled everything appart and put it back together 5 times in the last 3 days, i noticed that when i torqe the pressure plate down i dosent sit flush on the fly wheel, there is a small gap between the fly wheel and pressure plate, the car will not go in to gear at all, when i try to put it into gear it will start to move when i put pressure on the shifter trying to put it into first, i bleed the hell out of it and every thing,i think its just the clutch plate but i dont know? "it's a new clutch, was bought last year but was not put in till 2 weeks ago" this thing is driving me crazy i dont know what to do, PLEASE somebody help me figure this BS out.
if enyone needs more info on whats wron let me know
if eny one has an ACT 2600 thats near new let me know
FASTER AND FASTER! TILL THE FEAR OF DEATH IS OVER COME BY THE THRILL OF SPEED!!!
Old 05-31-2008   #2
Re: huge clutch issue need a little help
Are you saying there is a gap between where the clutch pressure plate physically touches the flywheel? In the six spots where bolts go, there should be no gap. Are the fingers on the clutch plate flat (before you tighten it, they are bent outwards towards the tranny side. As you tighten they flatten out)? Is the throwout bearing and fork properly installed?
Old 06-01-2008   #3
green hornet
ya where the bolt's go through the pressure plate there is a gap, i didnt take out the fork or the through out bearing, no the clutch plate has small gaps around the whole thing
Old 06-04-2008   #4
green hornet
knowone can help me on this
Old 06-04-2008   #5
AwdGSX13
AwdGSX13's Avatar
Drives: Cars
Well their isnt suppose to be a gap, I would start their? I would also be careful using clutches that have been sitting around. I put one in that had been sitting around and eventually the rubber bushing thingy's all dry rotted and split.
-Matt
'94 Eagle Talon TSI AWD
'06 Acura TL
Old 06-04-2008   #6
1QUICK4
Crash Course Racing
1QUICK4's Avatar
Drives: in circles
Sounds to me like you put the clutch disk in backwards. I've seen this before on a buddie's S-10 pickup.
If not, Did you center the clutch disk with a clutch alignment tool?
Are the dowels in place on the flywheel?
Old 06-04-2008   #7
Still have this problem?
Call Mike Standert and have me, or Blageo come over and take a look.
Old 06-05-2008   #8
green hornet
yep clutch is all in right made sure of that, i think its just a junk clutch im going to replace it this weekend and see what happens! i will keep everyone posted, mike had no clue what was wrong lol
Old 06-06-2008   #9
I said, call mike and have ME or Blageo come over LOL
Old 06-11-2008   #10
green hornet
i fixed it, my NEW craftsman tourq wrench is a pile of crap and was not tourqing to the right spec, when my buddy brought over his snap-on all my problems were fixed, and i cant even take back mine, thats the last time i buy eny tool's that have moving parts in them from sears, three weeks for nothing BLAAAAAAAAAAA lol
