Old 06-10-2008   #1
clean2g
Boost Junkie
clean2g's Avatar
Drives: I teleport
Broken turbo manifold stud
So I took the heat shield off that covers the turbo manifold, and I found a broken stud with the nut still intact. Judging by the length of the broken-off piece of the stud, I'm guessing I'd probably have to tap or take the head to a machine shop to get the rest out. So my question is, is it OK to drive the car around like that, boost and whatnot?
Old 06-10-2008   #2
HiImBrian
HiImBrian's Avatar
Drives: the girls crazy
Re: Broken turbo manifold stud
Which bolt is it exactly? A pic would probably help. I personally would not drive around with a mising bolt anywhere.
pics or gtfo
Old 06-10-2008   #3
AwdGSX13
AwdGSX13's Avatar
Drives: Cars
manifold studs to the head? if so it's not the end of the world. Just have it re- tapped. As for driving it, the only thing you may hurt is the gasket..
-Matt
'94 Eagle Talon TSI AWD
'06 Acura TL
Old 06-10-2008   #4
clean2g
Boost Junkie
clean2g's Avatar
Drives: I teleport
Yea, manifold to head. I'll try to get a pic up later. A good portion of the rest of the stud is still in the head, it looks like it broke off where the threads start in the head.
Old 06-10-2008   #5
HiImBrian
HiImBrian's Avatar
^have you tried using a reverse drill bit?
pics or gtfo
Old 06-10-2008   #6
It'll be fine, it's a DSM
Yank the manifold drill it, and easy-out it.
Old 06-11-2008   #7
bertrenolds5
bertrenolds5's Avatar
Drives: 91 eagle talon GST
You might as well replace all the studs when you have the mani off. Here is where I got my studs http://www.ssstuds.com/. Do what scheides said, you don't need to tear the engine apart to bring it in to a machine shop.
Old 06-11-2008   #8
AwdGSX13
AwdGSX13's Avatar
Drives: Cars
I had a local shop take my broken stud out and then helicoiled it. Worked great, never had problems. And I drove the car to them.
-Matt
'06 Acura TL
Old 06-11-2008   #9
clean2g
Boost Junkie
clean2g's Avatar
Drives: I teleport
Thanks for the help and info guys, I just lost my job so money is tight, but I'll look at both the machine shop or easy out options when I have some cash flow again.
