Old 06-11-2008   #1
v8klla
v8klla's Avatar
MAPerformance Inventory Clearance Sale *Updated / More Items*
As you may or may not know we are moving to a much larger space on July 1st of this year and we would rather sell this inventory than move it! This is a one time deal guys, check out the list below and contact us for pricing before it's too late!
ACL Honda Thrust Bearings
ACL Race Rod Bearings / 6 Bolt DSM / Standard Size
ACL Race Rod Bearings / Subaru / 52mm Rod Journal / Standard Size
ACL Race Rod Bearings / Subaru / 48mm Rod Journal / Standard Size
ACL Race Main Bearings / 6 Bolt DSM / Standard Size
ACL Race Main Bearings / 6 Bolt DSM / .25mm
ACL Race Main Bearings / Early 7 Bolt DSM w/Integrated Thrust / Standard Size
ACL Race Series Main Bearings / '97+ DSM & Evo
ACL Race Series Main Bearings (Honda D Series / H22A4 / F23)
ACL Race Main Bearings (Toyota/Lexus 1UZFE/2UZFE)
ACL Race Series Main Bearings / Subaru EJ Series / #5 Thrust Position
ACL Race Series Main Bearings / Subaru EJ Series / #5 Thrust Position / Extra Oil Clearance
ACL Race Rod Bearings (Toyota/Lexus 1UZFE/2UZFE)
ACT Street Disc / DSM
ACT 4 Puck Solid Disc / Evo
ACT Streetlite Flywheel / 6 Bolt AWD DSM
ACT Streetlite Flywheel / 7 Bolt AWD DSM
ACT Streetlite Flywheel / Evo
ACT Prolite Flywheel / Evolution VIII IX
ACT Streetlite Flywheel / STi
ACT 6 Puck Sprung Disc / DSM
ACT Heavy Duty Clutch & Flywheel / 6 Puck Sprung Disc / SRT-4
ACT Xtreme (2600) Pressure Plate / DSM
ACT Maxx (2900) Pressure Plate / DSM
ACT Heavy Duty Clutch Kit / 6 Puck Sprung Disc / Evo 8 & 9
ACT Heavy Duty Clutch Kit w/Street Disc (Evo)
ACT Xtreme Clutch Kit / 6 Puck Sprung Disc / Evo 8 & 9
ACT Xtreme Clutch Kit w/Street Disc (Evo)
ACT Heavy Duty Clutch Kit / 6 Puck Sprung Disc / 02-05 2.0l WRX
ACT Heavy Duty Clutch Kit / Modified Street Disc / 02-05 2.0l WRX
ACT Xtreme Clutch Kit / 6 Puck Sprung Disc / STi
AEM Bosch UEGO Replacement Sensor
Aeromotive A1000 EFI Adjustable Fuel Pressure Regulator / -6AN
Apex'i Neo Air/Fuel Controller
Apex'i Auto Timer / Black
ARP Rod Bolts / Pre '94 DSM
ARP Extended Length Flywheel Bolts / DSM & Evo
ARP Balancer Bolt / 4g63
ARP Head Studs / 6 Bolt DSM
ARP Head Studs / 7 Bolt & Evo
ARP Main Studs / 4g63
ARP Head Studs / Subaru WRX & STi
ARP Extreme Duty Head Studs / 6 Bolt DSM
Autometer Replacement Bulb and Socket / No. 168 / 4.9 Watt
Autometer Tubing and Line Kit / 10' Long 1/8" Diameter
Autometer Replacement Bulb and Socket *Replaces bulbs 161, 193, 194, and 168 only
Brian Crower Valve Springs and Retainers / DSM & Evo
Brian Crower Stage 2 Camshafts / Evo 8
Brian Crower Stage 3 Camshafts / Evo 8
Brian Crower Stage 3 Camshafts / Evo 9 MIVEC
Brian Crower Valve Springs & Retainers / Subaru EJ Series
Brian Crower Stage 2 Camshafts / EJ205 WRX
Brian Crower Stage 4 Camshafts / EJ205 WRX
Brian Crower Stage 3 Camshafts / EJ257 STi
Booger Shifter Bushings / SRT-4
CHM Fuel Pressure Gauge
Clevite Rod Bearings / 2g DSM & Evo / .50mm
Clevite Main Bearings / 95-96 DSM / .50mm
Cobb Tuning Exhaust Hangers / Subaru
Cobb Tuning AccessPORT / Subaru WRX 2006-07 / Subaru STi 2004-2007
Cobb Tuning AccessPORT / Subaru Impreza WRX 2008
Cometic Head Gasket / DSM / 85.5mm Bore / .051" Thickness
Cometic Head Gasket / DSM / 86mm Bore / .051" Thickness
Cometic Head Gasket / DSM / 87mm Bore / .051" Thickness
Cometic Head Gasket / Subaru EJ25 / 100mm Bore
Cometic Head Gasket / 420a / 88.5mm
Cosworth Mitsubishi 4G63 (EVOVII-VIII) High Performance Main Bearing Set
Crower Valve Spring & Retainer Set / EJ20
Dark Performance T4 Manifold / DSM
Defi Triple Meter Hood for New Age Impreza
Eagle Connecting Rods / Honda B16 (except JDM B16B)
Eagle Connecting Rods / Honda D16 & ZC
Eagle Connecting Rods / Honda B18C
Eagle Connecting Rods / 6 Bolt DSM
Eneos 0W50 Fully Synthetic Motor Oil
Eneos 5W30 Synthetic Blend Motor Oil
Eneos 5W40 Fully Synthetic Motor Oil
Exedy Stage 1 Organic Clutch Kit / STi
Exedy HD Twin Disc Clutch Kit / Evo
Ferrea Exhaust Valves / 1mm Over / EJ257 (Set of 8)
Ferrea Intake Valves / 1mm Over / EJ257
Exhaust Valve Stem Seal / DSM & Evo(Set of 8)
Fuel Injector Clinic 650cc Injectors / DSM
Fuel Injector Clinic 750cc Injectors / DSM
Fuel Injector Clinic 850cc Injectors / DSM
Fuel Injector Clinic 950cc Injectors / DSM
Fuel Injector Clinic 1050cc Injectors / DSM
Fuel Injector Clinic 1150cc Injectors / DSM
Fuel Injector Clinic 1600cc Injectors / DSM
Fuel Injector Clinic 750cc Injectors / Evo
Fuel Injector Clinic 850cc Injectors / Evo
Fuel Injector Clinic 950cc Injectors / Evo
Fuel Injector Clinic 1050cc Injectors / Evo
Fuel Injector Clinic 1150cc Injectors / Evo
Fuel Injector Clinic 900cc Injectors / SRT-4
Fuel Injector Clinic Complete Seal Kit for 4 Injectors 550cc-1150cc (Includes Viton Lower Seals)
Fidanza Aluminum Flywheel / Subaru Impreza 2.5L
Fidanza Aluminum Flywheel / Subaru WRX STi
Fidanza Aluminum Flywheel / 6 Bolt FWD DSM
Fidanza Aluminum Flywheel / 6 Bolt AWD DSM
Fidanza Aluminum Flywheel / 7 Bolt AWD DSM
Fidanza Aluminum Flywheel / 7 Bolt FWD DSM
Fidanza Aluminum Flywheel / Evo 8
Fidanza Replacement Friction Surface / DSM
Fidanza 4.3 Clutch Kit / Subaru 2.0L WRX
Fidanza 2.1 Clutch Kit / DSM
Fidanza 3.2 Clutch Kit / DSM
Fidanza 4.3 Clutch Kit / DSM
Fidanza 3.2 Clutch Kit / Evo 8 (5 Speed Only)
Fidanza 4.3 Clutch Kit / Evo 8 (5 Speed Only)
Fidanza Short Shifter / WRX
Fidanza Short Shifter / Evo
Fidanza Short Shifter / SRT-4
Fidanza Adjustable Cam Gears / Silver / B-Series Honda & Acura (Pair)
Fidanza Adjustable Cam Gear / Dodge SRT-4 (Clear / Pair)
Fidanza Adjustable Cam Gear / Dodge SRT-4 (Blue / Pair)
Forced Performance Exhaust Manifold Stud & Nut Kit / 6 Bolt
Forced Performance Exhaust Manifold Stud & Nut Kit / 7 Bolt
Fuelab Filter, In-Line Long Length AN -10 Inlet/Outlet (40 micron Stainless Steel element)
Gates Racing Timing Belt / 4g63
Greddy Timing Belt / WRX & STi
Hallman ES Manual Boost Controller / Black
Hallman Pro Manual Boost Controller / Black
Hawk Performance HPS Brake Pads / Front / 97-01 Impreza
Hawk Performance HPS Brake Pads / Rear / '02-'03 Subaru WRX
Invidia SS Downpipe / Open Bellmouth / WRX & STi
Invidia N1 Catback Exhaust System / WRX & STi
Invidia N1 Racing Catback Exhaust System / WRX & STi (No Resonator)
Invidia G200 Catback Exhaust System / WRX & STi
Invidia SS Downpipe / Evo
Invidia G200 Cat Back Exhaust System / Evo
Invidia N1 Catback Exhaust System / Evo
Invidia Turbo Outlet / Evo
Invidia SS Downpipe / Catted / Divorced Wastegate / WRX & STi
Invidia SS Downpipe / Non-Catted / Divorced Wastegate / WRX & STi
K&N Performance Gold Oil Filter / Subaru WRX & STi
K&N Performance Gold Oil Filter / 7 Bolt DSM & Evo
2.5" Aluminized Steel 90 Degree Bend
2.5" Aluminized Steel Combo Bend / 180 Degree + 45 Degree
2.5" Stainless Steel 105 Degree Bend
2.5" Stainless Steel 110 Degree Bend
3" Aluminized Steel 90 Degree Bend
3" Aluminized Steel Combo Bend / 180 Degree + 45 Degree
3" x 6" Braided Flex Section
Exhaust Hanger
Megan Racing 3" SS Test Pipe / Evo
Mishimoto Aluminum Radiator / 95-99 Mitsubishi Eclipse Turbo, Manual
Mishimoto Aluminum Radiator / 03-06 Mitsubishi Lancer Evolution, Manual
Mitsubishi OEM O2 Housing to Downpipe Gasket
Balance Shaft Elimination / Block Off Cap
Balance Shaft Elimination / "Stub" Shaft
Mitsubishi Balance Shaft Bearings
Mitsubishi Exhaust Manifold Gasket / DSM
Mobil 1 0w40 Synthetic Motor Oil
Mobil 1 10W30 Synthetic Motor Oil
Mobil 1 15w50 Synthetic Motor Oil
Mobil 1 15w50 Extended Performance Synthetic Motor Oil
Mobil 1 5w30 Synthetic Motor Oil
Mobil 1 Synthetic ATF
Mr. Gasket Fluidzap Pad
1.3 Bar Radiator Cap
Chris Carey, President
Modern Automotive Performance
P: 763-545-3800
E: chris@maperformance.com
Old 06-11-2008   #2
v8klla
v8klla's Avatar
Re: MAPerformance Inventory Clearance Sale *Updated / More Items*
NGK Copper Spark Plugs / WRX / Heat Range 7 (1)
NGK Iridium Spark Plugs / WRX / Heat Range 7 (4)
NGK Iridium Spark Plugs / WRX / Heat Range 8 (4)
NGK Iridium Spark Plugs / DSM & Evo VIII / Heat Range 7 (4)
NGK Copper Spark Plugs / DSM & Evo VIII / Heat Range 7 (1)
NGK Copper Spark Plugs / DSM & Evo VIII / Heat Range 8 (1)
NGK Iridium Spark Plugs / DSM & Evo VIII / Heat Range 9 (4)
NGK Copper Spark Plugs / DSM & Evo VIII / Heat Range 9 (1)
NGK Iridium Spark Plugs / STi / Heat Range 7 (4)
NGK Iridium Spark Plugs / SRT-4 / Heat Range 6 (4)
Perrin Performance Shorty Antenna 4" Evo VIII/IX
Perrin Performance Fuel Rail Upgrade System / Red / Evo
Perrin Performance Front Mount Intercooler System / Evo
Perrin Performance Front Mount Intercooler System / Stealth / Black
Perrin Performance SS Downpipe / 3" / Evo
Perrin Performance 3" Cat Back Exhaust System / Evo
Perrin Performance Catback Exhaust / Stealth / Evo
Perrin Performance Adjustable Endlinks / Rear / Evo
Perrin Performance Front Mount Intercooler Kit / WRX & STi
Perrin Performance Radiator Shroud / WRX & STi / Black
Perrin Performance Downpipe / Front Section / '06-'07 WRX
Perrin Performance Downpipe / Rear Section / '06-'07 WRX
Perrin Performance Sport Tone Exhaust / Single Tip / Stealth / WRX & STi
Perrin Performance Afta-Maf Tube / WRX & STi / Black
Perrin Performance Intercooler Hose Kit / Drive By Cable
Perrin Performance Recirculating Blow Off Valve / Black / WRX & STi
Perrin Performance Recirculating Blow Off Valve / Red / WRX & STi
Perrin Performance Sway Bar Kit / STi / 22mm / Front and Rear / Includes End Links and Mounts
Perrin Performance Endlinks / Front / WRX & STi
Perrin Performance Sway Bar / 22mm / Adjustable / WRX
Perrin Performance Sway Bar / 25mm / Rear / STi
Perrin Performance Rear Endlinks / 93-07 Impreza & WRX
Perrin Performance PSRS / WRX
Prosport Mechanical Boost Gauge / 30psi / Blue
Prosport Mechanical Boost Gauge / 45psi / Blue
Prosport Electronic Boost Gauge / 30psi / Blue
Prosport EGT Gauge with Sensor / Blue
Prosport Water Temp Gauge with Sensor / Blue
Prosport Air/Fuel Ratio Gauge (Narrowband) / Amber-White
Prosport Mechanical Boost Gauge / 30psi / Amber-White
Prosport Electronic Boost Gauge / 30psi / Amber-White
Prosport EGT Gauge with Sensor / Amber-White
Prosport Oil Pressure Gauge with Sensor / Amber-White
Prosport Oil Temperature Gauge with Sensor / Amber-White
Prosport Water Temp Gauge with Sensor / Amber-White
Prosport Mechanical Boost Gauge / 30psi / Green-White
Prosport Electronic Boost Gauge / Green-White
Prosport Exhaust Gas Temperature Gauge with Sensor / Green-White
Prosport Fuel Pressure Gauge / Green-White
Prosport Premium Series Electronic Boost Gauge / Amber-White / Units=Bar
Prosport Premium EGT Gauge with Sensor / Amber-White
Prosport Premium Oil Pressure Gauge with Sensor / Amber-White
Prosport Premium Electronic Boost Gauge / Green-White
Prosport Premium Water Temp Gauge with Sensor / Amber-White
Prosport Oil Filter Adapter Plate / Subaru, Honda, Ford, Mazda, Mitsubishi
Prosport 52mm Mounting Cup / Black Plastic
Precision Turbo Inlet Turbine Gasket / T3
Precision Turbo Inlet Turbine Gasket / T4 Open
Precision Turbo Inlet Turbine Gasket / T4 Divided
Punishment Racing T3 4 Bolt O2 Housing / Stainless Steel
QuarterMaster Flywheel / 7 Bolt DSM
Quaife Front Differential / Evo 8 & 9
Redline MTL Gear Oil
Redline MT90 Gear Oil
Remflex Universal 3" / 2 Bolt Gasket (4-1/8" Spacing)
Royal Purple 5w30 Synthetic Motor Oil
Russell AN to Metric Adapter Fitting / -6 AN to 14mm x 1.5 Male / Straight
Samco Sport VW Golf Mk4 / Beetle / Audi TT 180 / Seat Leon / Skoda Octavia Turbo Induction (Red)
Scat Enterprises Connecting Rods / 6 Bolt DSM
Summit Brand Weld In Aluminum Bung / -6an
Tial BOV Weld Flange / Mild Steel
Topline Complete Block Gasket Set / 7 Bolt DSM
Topline Complete Block Gasket Set / 6 Bolt DSM
Topline Complete Gasket Set / 1g 7 Bolt DSM
Topline Complete Gasket Set / 2g DSM
Topline Complete Gasket Set / 6 Bolt DSM
Topline Freeze Plug Set(Nine 35mm Plugs / DSM
Topline Exhaust Valve Guides / DSM (Set of 8)
Topline Head Gasket Set / 1g 7 Bolt DSM
Topline Head Gasket Set / 2g DSM
Topline Head Gasket Set / 6 Bolt DSM
Topline Intake Valve Guides / DSM (Set of 8)
Topline Revised Lifters / DSM & Evo (Set of 16)
Topline Oil Pump / 6 Bolt DSM
Topline Pistons with Rings Set / Standard Bore / 6 Bolt DSM
Topline Pistons with Rings Set / .020" Overbore / 6 Bolt DSM
Topline Water Pump / 1g 7 Bolt DSM
Topline Water Pump / 1g 6 Bolt DSM
Trick Flow Hose End / Black / 90 Degree / -8 AN Hose to Female -8 AN
Venair 2.5" to 2" Reducer Coupler
Venair 3" to 2.5" Reducer Coupler
Venair 2" 90 Degree Elbow
Venair 2.5" 90 Degree Elbow
Venair 3" 90 Degree Elbow
Venair Straight 2" Coupler
Venair Straight 2.5" Coupler
Venair Straight 3" Coupler
Vibrant Performance SS O2 Bung
Vibrant Performance O2 Plug
Vibrant Tial / Ultragate (oval 2 bolt) Wastegate Flange, 1/2" Thick
Vibrant T304 Stainless Steel Tial / Deltagate / Turbosmart 35-38mm External Wastegate Flange (Ta...
Vibrant 35-38mm External Wastegate Flange w/ Tapped bolt holes (3/8" thick)
Vibrant 4 bolt GT30/GT35 Discharge Flange / 3" I.D. / 1/2" thick / SS
Vibrant 4 bolt GT30/GT35 Discharge Flange / 3" I.D. / 1/2" thick / Mild Steel
Vibrant 4 bolt GT30/GT35 Discharge Flange / 2.5" I.D. / 1/2" thick / SS
Vibrant 4 bolt GT30/GT35 Discharge Flange / 2.5" I.D. / 1/2" thick / Mild Steel
Vibrant 2-Bolt Stainless Steel Flange (2.5" I.D.)
Vibrant 2-bolt Stainless Steel Flange (3" I.D.)
Vibrant Performance 4 Ply Reducer Coupling, 2.5" x 3" x 3" long - Black
Vibrant T-Bolt Clamp / For use with 2.75" couplers
Visteon Aluminum Radiator w/Spal Fan / 2g N/T DSM
Walbro Installation Kit / '84-'92 Toyota Supra Turbo
Walbro Installation Kit / '89-'94 Nissan 240SX
Walbro Installation Kit / Subaru
Walbro Installation Kit / '94-'00 Acura Integra / '92-'00 Civic & Del Sol
Walbro Installation Kit / 2g DSM & Evo
Walbro Installation Kit / '89+ Mazda RX7
Walbro Installation Kit / 1g AWD DSM
Walbro Installation Kit / '97+ Honda Prelude
Walbro Installation Kit / 1g DSM FWD
Walbro Installation Kit / '90-'93 Acura Integra & Honda Accord
Walbro 255lph Fuel Pump / SRT-4
Walbro 255lph HP Fuel Pump
Whiteline Steering Rack Bushing Kit
Wilwood PolyMatrix E Compound Brake Pads / Dynalite Single Front Axle
Wiseco Pistons / 7 Bolt 4g63 / 86.5mm Bore
Wiseco Pistons / 6 Bolt DSM / 2.0l / 86mm Bore / 8.3:1 CR
Wiseco Pistons / 7 Bolt DSM & Evo / Standard Bore
Zeitronix 5 Bar MAP Sensor
Zeitronix EGT Probe and Extension Harness
Zeitronix Black LCD Wideband Bundle
Zeitronix ZR-2 Wideband Bundle (Blue)
Zeitronix ZR-2 Wideband Bundle (Red)
P: 763-545-3800
Old 06-11-2008   #3
I highly recommend the Fidanza short-shifter for the Evo! It even includes the shifter base bushings.
Old 06-14-2008   #4
CarRacer
CarRacer's Avatar
Drives: 91 Galant VR4
Pricing on a Walbro 255hp and 1g awd install kit along with the aeromotive regulator would be great. Does that regulator include the required hoses to the fuel rail?(Install Kit)
Thanks
CarRacer is offline   Reply With Quote
Old 06-14-2008   #5
v8klla
v8klla's Avatar
PM sent thanks!
P: 763-545-3800
Old 06-22-2008   #6
justinhill
BetHiLow Streak Un-Censored Champion! League Bowling Champion! Snowboard Champion!
Drives: 98 gst eclipse
Send a message via AIM to justinhill
whats the price on Prosport EGT Gauge with Sensor / Blue
justinhill is offline   Reply With Quote
Old 06-23-2008   #7
v8klla
v8klla's Avatar
I'm showing 1 left, $89.99 let me know!
P: 763-545-3800
Old 06-26-2008   #8
Hoffer00
Cantankerous Tank Champion! Fight Man Champion! Go Johnny Go Champion!
Send a message via Yahoo to Hoffer00
I'm thinking about the Apex'i Neo Air/Fuel Controller. Does it need anything else to work and whats the price. I think I am starting to knock at high speed after cruising for a while.
Hoffer00 is offline   Reply With Quote
Old 06-26-2008   #9
Price for the Prosport 45psi mechanical boost gauge? Also, does that gauge show vacuum also, or only boost?
Old 06-26-2008   #10
v8klla
v8klla's Avatar
Nope just needs to be wired in!
P: 763-545-3800
Old 06-26-2008   #11
v8klla
v8klla's Avatar
$34.99 and no only boost
P: 763-545-3800
Old 06-26-2008   #12
Thanks anyhow. Do you have any other options as far as boost gauges go that go higher then 30psi, but still show vacuum?
Old 06-26-2008   #13
v8klla
v8klla's Avatar
nothing in stock, but I know autometer makes something we could have next day more than likely, let me know!
P: 763-545-3800
Old 06-26-2008   #14
Hoffer00
Whats the CLR price
Whats the price with install and tune.
PM please
Old 06-26-2008   #15
v8klla
v8klla's Avatar
$299.99, install is about $220, tuning is to be determined as we have a new tuner starting Monday
P: 763-545-3800
Old 06-30-2008   #16
Hoffer00
Would I need anything else to have the car tuned or is the Neo afc good enough
Old 06-30-2008   #17
v8klla
v8klla's Avatar
the only other thing you need is a wideband, so as long as your on the dyno you're all set
P: 763-545-3800
Old 06-30-2008   #18
longemoco
how much for the fidanza aluminum flywheel fro a 2g GST? and topline complete gasket set for 2g?
longemoco is offline   Reply With Quote
Old 07-02-2008   #19
Burd@MAP
Drives: 05 Srt-4
PM Sent
Burd@MAP is offline   Reply With Quote
