Old 03-05-2004   #1
Battery
For anybody needing extra room or lighter wieght. Raptors good for a dozen of them.
Old 03-05-2004   #2
Raptor
ConArtist
Raptor's Avatar
Actually, that is the one thing I won't compromise. I mounted my full size battery in the trunk and wired a relay system inline with my altenator so I can eliminate draw on it and run from the battery for the 1320. I like the effect of moving the weight to the back for traction purposes as well as the un-cluttered engine bay, but I wouldn't go the small battery route even though I know plenty who have without noticeable issues. I keep weight in mind with everything I do, but there are times when heavier is better for performance.
Quick Precision Racing, Inc.
"Always Raising the Bar!"
651-488-7774
Old 03-06-2004   #3
Jacek
Captain J-Sack
for putting your battery in the trunk, what did you do about the battery venting?
Old 03-06-2004   #4
Raptor
ConArtist
Raptor's Avatar
I went with the same NHRA approved Taylor box that Ryan "MustGoFaster" is asking Elite about. It has the vent that you just route out of the car through the floor and a grommet. It is a very nice setup.
651-488-7774
Old 03-06-2004   #5
My battery is lighter than that one 10.8 lbs.
Old 03-06-2004   #6
Do you have any source for them anymore? All of ours are dead.
Old 03-06-2004   #7
i will be getting a flywheel that is a little more than that! yay! 11lbs
Old 03-06-2004   #8
Originally posted by ecoli+Mar 6 2004, 01:52 AM--></div><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (ecoli @ Mar 6 2004, 01:52 AM)</td></tr><tr><td id='QUOTE'> <!--QuoteBegin-TalonTSiDude@Mar 6 2004, 12:38 AM
My battery is lighter than that one &nbsp; 10.8 lbs.
Do you have any source for them anymore? All of ours are dead. [/b][/quote]
I've been working on it...nothing 100% yet but I'll let you know if I get something.
Old 03-06-2004   #9
Originally posted by ecoli+Mar 6 2004, 12:52 AM--></div><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (ecoli @ Mar 6 2004, 12:52 AM)</td></tr><tr><td id='QUOTE'> <!--QuoteBegin-TalonTSiDude@Mar 6 2004, 12:38 AM
I just picked up two from Tevenor, check with him, he's got more.
Old 03-06-2004   #10
Raptor
ConArtist
Raptor's Avatar
Notice a trend here?
I have the same old battery in my car that it came with, I just moved it. It is probably 4 years old and still holds a charge just fine, hasn't needed a jump once in any weather. I am also confident that it can support my ignition system at high RPM without the aid of the altenator. I can't say that about the small batteries. I am assuming that everyone is running them mainly to save weight and get the associated power savings that goes along with it. Consider this though, if you are saving 20 lbs going with that battery, and the statement is true that a 100lbs is worth a tenth in the 1320 you are less than a 2HP advantage from the weight loss. If you kill your altenator for the run and go from the batteries power, you are probable closer to saving 3-5HP and possibly more, I have heard alot of different numbers on that over the years. Also, by moving it to the back, you have more even weight distribution and can place it directly over the most significant tire (RR).
I am interested in anyone elses opinions of what I am talking about. Try and shoot holes in what I am saying if you can, I am always open for a better way of doing anything.
651-488-7774
Old 03-06-2004   #11
Look at your voltage when you are under power with and without an alternator. If you have a very strong battery you will see 12.3 volts or so without the alternator. With the alternator you will see about 14 volts. Which do you think is going to supply the ignition with more power? We already know the effect that the voltage has on the fuel pump, that is why we rewire them.
There is a way around that though. Jacobs makes a product called the Accuvolt that will bump the voltage up to 14.4 volts no matter what the incoming voltage is. If you put one of those on the ignition and fuel pump, you would be set! They aren't real cheap, but it is a good option.
Old 03-06-2004   #12
We run 16volt batteries on drag cars that don't use an alternator.
Old 03-06-2004   #13
Raptor
ConArtist
Raptor's Avatar
That sounds like a smart option. I know there are companies like Taylor that manufacture altenators that cut out the charging function if the car is at WOT and the batteries have adequate charge. Running without altenators in drag racing is not a new concept, it has been done for years even on cars without magnetos. the 16 volt battery does sound like it would be a good idea.
One of the reasons the small battery thing kills me is the guys who have put them in heavy cars with no real other weight reductions. I can see running one in a car that has been well thought out and lightened, but running one in a heavy boat is pretty much pointless other than if there is some space requirement.
That is not pointed at anyone who posted in this thread yet. I saw a few that fit that description on Uni last year.
I remember looking up the Jacobs thing last year when you mentioned it JET. It is pretty expensive and designed mainly for sound systems, but it could work. I would bet the higher voltage battery/charging system is probably the best method if finances are not an issue though, considering the extra complexity/weight of additional equipment with the Jacobs setup.
651-488-7774
Old 03-06-2004   #14
Raptor
ConArtist
Raptor's Avatar
After further reading, the 16volt battery would be good for race only for the simple fact that without serious modification to the charging system, you would need to keep it charged with an external charger and at that level not bother with an altenator at all.
I am still going to dig on this since I know there are always a lot more things to consider than just the basics. Ideas like JET mentioned are things that are worthwhile to look into. Either way, it boils down to the facts that every system on the car must be up to par to be competitive.
651-488-7774
Old 03-06-2004   #15
JoeGengsta
Send a message via AIM to JoeGengsta
the small battery is NOT a practical choice, for instance, lets look at Kirchhoff's law that states
L(dI/dt) +RI + (1/C)Q = E(t) where voltage drop across the resistor is IR, voltage drop across the capacitor is Q/C, and lotage drop across the inductor is LdI/dt, comined you have the relationship of 1 volt * 1 ampere = 1 coulomb/1 farad = 1 henry * 1 ampere/1 second. The comibination of all of this resembeles the electrolytic behavior of your circuity within the car. Now, take something with 1/3 the electrolytic capacity, the small battery would certainly power the car, run the radio, and your sparks for the plugs.. but wait... what would happen if you plugged in something that requires 12 volts and a few amps, or perhaps what do you think would happen if your car didn't have the electrolytic potential to power the cominbation of your highbeams, your factory stereo and what not.. oh i guess intra charge < forced charge which means that your car may not be able to make it home. anyway, electrical physicts and ciruit board engineers created a BIGer battery for a reason, why mess with it? anyway, my name is Joe and i fart a lot.
Subaru Impreza STi
JoeGengsta is offline   Reply With Quote
Old 03-06-2004   #16
-GSX-Falcon
Guest
Tournaments Won: 6
Posts: n/a
I must be stupid. 90% of that sounds like a different language....I still kind of understand....
Old 03-06-2004   #17
Alternator?
Old 03-06-2004   #18
JoeGengsta
yes, the alternator flows like dX/dt, where X is the charge input and t is time. (change of charge in respect to time), but remember, i'm saying if there is a burst of electrical withdrawl, the SYSTEM will die.
in addition, remember that the entrance of frictionally created charge by the alternator is all in respect to the cycles of the engine, more RPMS = more cycles = more charge that the alterantor generates through its supercoil. so, what happens at a stop light when all your electronics are on? hmm... the charge can be distributed inadequetly/unevenly to your componenets which can cause misreads on your electrical gauges, misreads in your audio equipment, misreads in your sensors, and so forth. so why bother doing it?for the 7 pounds or what not saved? maybe people should just go on a diet and stop worrying about how much faster 7 pounds can get u, besides, think of the accelatory coeffienct that powers 7 more pounds.. i dont see the benefit.
Subaru Impreza STi
Old 03-06-2004   #19
We are talking about fast cars here, not normal daily driven cars with enough neon lights to light up the sky and a sound system that knocks the body kits off of honda's. If you require more power than the alternator puts out, you are in trouble. The batteries in question are gel cells too, so their capicity is larger per pound than the bigger batteries. They are still smaller capacity though.
The difference is actually 30 pounds, not 7.
Old 03-06-2004   #20
The only bad thing with a rear mounted battery in our cars is using the chassis as a ground. There's a lot of interference in a unibody chassis and that could hurt your battery's performance. If you're running a large power and ground cable(0-1awg), things should be fine.
I had a rear mounted battery, I didn't like the extra complication so I put the mini battery up front directly on the subframe. Does exactly what I want, saves me 20+ lbs and they're cheap. So I have to replace it each year at $20 a crack, fine with me.
