Old 06-24-2008   #1
Speedfreak
Drives: four tires
Fuel Pressure Regulator
I need a FPR for my 1g dsm. Let me know what you got, and what you want for it.
Old 06-24-2008   #2
Re: Fuel Pressure Regulator
Just a stock one? I think I have a stock 1G one laying around here.
Old 06-24-2008   #3
Speedfreak
Drives: four tires
lol no, sorry, I need an aftermarket FPR.
Old 06-26-2008   #4
Speedfreak
Drives: four tires
What are the options for FPR's on dsm's? I was bidding on one of those SX/Buschur fpr's on ebay, but it's gonna go high I'm betting. Does anyone just use an Aeromotive A1000-6 or whatever and mate it somehow to the stock lines and rail?
Old 06-27-2008   #5
At-Least-It's-An-Evo
At-Least-It's-White-Again
At-Least-It's-An-Evo's Avatar
Drives: 98 iVTEC
http://www.dsmparts.com/customer/pro...cat=164&page=1
'04 Honda Ricer: stock
Old 06-27-2008   #6
Speedfreak
Drives: four tires
Cool, thanks Cher. Tpunx99GSX aslo showed me this:
http://www.extremepsi.com/store/cust...at=1559&page=1
I think I'll go this route for now. I have a A1000-6 that I have for the other car.. I'll just use it on the gsx for now and get another when I have time to finish the other car.
Old 06-27-2008   #7
http://importevolution.com/product_i...oducts_id=1620
That's the one I have. Uses push-lock hose which helps keep the cost down a little bit by not using the braided bling hose.
Old 06-27-2008   #8
tim
tim's Avatar
Pushlock hose is the way to go, imo. You dont get the fuel vapor like you do from braided and it is much easier to work with.
Old 06-27-2008   #9
I have this one, it's nice because it bolts right to a 1g rail:
https://secure.buschurracing.com/cat...roducts_id=427
EDIT: I picked mine up used with a 255 pump for $125 I think, you can find them much cheaper than at buscher.
Old 06-27-2008   #10
Speedfreak
Drives: four tires
OK, well what I need is the fitting that bolts to the stock 1g fuel rail, then any/all fittings that go from there to the regulator, then a fitting to connect to the stock return line. So if I were to go the push-lock route, I need to figure out what I need and where to buy the stuff individually.
I already have:
Aeromotive A1000-6 FPR
Bosch 044
PTE 1200's will be ordered next week.
Old 06-27-2008   #11
Speedfreak
Drives: four tires
So I can get push lock hose from a vendor, and I haven't looked around, who makes those fittings?
Old 06-28-2008   #12
Drives: 98 iVTEC
I already have:
Bosch 044
Why don't you get 1600's and call it good for whatever it makes?!?!?
Old 06-28-2008   #13
Speedfreak
Drives: four tires
I want the 1200's for the smaller/shorter pulse width. I can try to tune part throttle for some gas mileage. And I should be able to make good power with the 1200's I think. Matt Dean made like 460 something awhp with close to the same setup but the walbro ran out and the injectors still had room left. I'm hoping for 500+awhp?(maybe on E98)
