Old 03-06-2004   #1
SquackDiddy
Send a message via AIM to SquackDiddy Send a message via MSN to SquackDiddy
just wondering
I am on suspension because I refuse to type a decent sentence.
SquackDiddy is offline   Reply With Quote
Old 03-06-2004   #2
jimwross
Guest
Tournaments Won: 6
Posts: n/a
TD05-14B (stock 1st gen) 405 CFM 275hp @ 19 psi
Sorry I didnt see with porting... that is just the stock statistic
Old 03-06-2004   #3
SquackDiddy
its cool. it could hold at 19 psi? whats the highest psi it could go up to, with out droppin?
Old 03-06-2004   #4
jimwross
Guest
Tournaments Won: 6
Posts: n/a
Dunno... just a stat I found from the vfaq @ dsmtuners
Old 03-06-2004   #5
The efficiency will start to drop off pretty quickly after 20psi.
Old 03-06-2004   #6
The better your system flows the less boost it will be able to hold. Usually they hold about 17-19psi to redline on a basic mods 1G. You can run more though. Mara's made 298whp on race gas with basic ghetto mods and trapped a best of 108.6 mph. You could make more with some fancier supporting mods.
Old 03-07-2004   #7
1Fst14B
on my car, the 14B would hit whatever boost you wanted, but would drop to just a little over 20 psi by 6.25k.
dont go to redline on the 14B, even with supporting mods, power drops off fairly quick
as for power, i made 250hp on 15 lbs with no tuning (550's and 2G MAS, no AFC) which would basically run like crap on the street and bog out horribly...
max power has gotta be 300-330 to the wheels, with some good gas... i am guessing thats what i was around, but im sure there was more potential if it was acually tuned and running good
Adam
