Old 07-03-2008   #1
URV8SUX
URV8SUX's Avatar
Turbo, FMIC, gauges, etc. for sale
Here is what you need............. Was all used for about 800 miles.
P-Trim 67mm T4 .58A/R (different exhaust housings T3 .63, T3 .82, T4 .68 ,or .T4 .83)
Turbo has 0 shaft play and no chiped fins
2.5 90 welded on the compresser cover
PTE 600 HP IC (over all 31.5L x 8H x 3.5D 2.75 In and out.)
Tial 38mm WG .5 bar spring (black)
38mm WG flang, gaskets, and some piping
Tial 50mm BOV (black)
With flang and O-ring
K&N filter
-4 feed line with 1/8ntp 90 for tubo
-10 return with 90 degree fitting (12 ichcs long)
T bolt clamps
V-band and clamp
Old down pipe (3 inch) O2 bung in DP
2.5 inch pipng
$1500 is worth $2840
Auto Meter spot comp gauges
Boost 30psi (mechanical)
Water temp (electric with sensor)
Volts (electric)
Oil Pressure (mechanical)
Aem wideband with sensor
$400 bucks
Old 07-03-2008   #2
Re: Turbo stuffffffffffffffor YOU!
http://mitsustyle.com/forums/showthread.php?t=19453
Title: "Turbo stuffffffffffffffor YOU!"
Really? I will change it for you this time.
Old 07-03-2008   #3
mike55112
mike55112's Avatar
Drives: 04 evo
Re: Turbo, FMIC, gauges, etc. for sale
How much just for the boost and wideband?
Old 07-09-2008   #4
brando
Drives: gutlass
this is all for a 1g right?
Old 07-09-2008   #5
Came off a 2G VW Golf.
Old 07-09-2008   #6
User Name
Hates blue couplers.
User Name's Avatar
Drives: White 1Gb TSi
I want the wb02 w/ sensor. Pm me price if interested in parting it from the rest of them gauges.
ForSale:
90 OFH+Cooler/AN fittings
FIC 850
FP Turbo kit
Old 07-09-2008   #7
brando
Drives: gutlass
wait is this nate posting this?
