Old 07-11-2008   #1
chengsta
chengsta's Avatar
Drives: '93 mirage es - evoIII
horrible gas mileage cause?
My '99 eclipse spyder gst has been getting horrible gas mileage withing the last 2 weeks. While the car is cruising at a coast, it would slightly shake and sputter like it was misfiring. I had a check engine light: P0136 Bank 1 Sensor 2 which would be the 2nd o2 sensor by the cat. So I replaced that o2 sensor and put new NGK BPR7ES plugs(gapped at .030) figuring it would solve the sputter/misfiring but still no luck.
I reseted and checked the ECU again for any new codes and it through this code now:
-P0125 Insufficient Coolant Temperature for Closed Loop Fuel Control
I've done some research and found out this code might be caused by a bad FRONT o2 sensor. Would this be the cause for my bad gas mileage?
1993 Mitsubishi Mirage ES - soon to be EVOIII...
chengsta is offline   Reply With Quote
Old 07-11-2008   #2
Re: horrible gas mileage cause?
It would cause bad gas mileage. If its the O2 then the computer is probably running super rich because it doesnt know what kind of air/fuel ratios you are getting.
1998 Spyder AWD
567hp
490tq
Old 07-11-2008   #3
xveganxcowboyx
Wanker
xveganxcowboyx's Avatar
Drives: 95 M3
What sort of coolant temperatures are you seeing? It sounds like you are either not getting up to temp or the soolant temp sensor is reading wrong, both of which would cause you to run rich.
Old 07-11-2008   #4
On a 2g that code can mean front O2 sensor too. I had a 95 talon that had the same problem. replaced the front O2 and problem fixed.
1998 Spyder AWD
567hp
490tq
Old 07-11-2008   #5
xveganxcowboyx
Wanker
Drives: 95 M3
That's weird. I like my OBD1.
Old 07-11-2008   #6
chengsta
chengsta's Avatar
I'm not quite sure what coolant temps it gets up to since I don't have a logger. The car doesn't overheat or anything though.
I have a new front o2 sensor on order from the local parts store, should be here sunday. I'll install it then and see if the solves the problem.
Old 07-13-2008   #7
chengsta
chengsta's Avatar
installed new front o2 sensor and it solved it. No more stuttering or misfiring.
Old 07-13-2008   #8
gofastman
James Bond... James Bond
gofastman's Avatar
Drives: 95 Jeep
Send a message via AIM to gofastman
You are high, nobody likes OBD 1
-David C.
Originally Posted by bouncer07
If you know Mary Clifford, Ph,.D. Associate Professor of Criminal Justice in St. Cloud State University. Then your well aware of who she is.
gofastman is offline   Reply With Quote
Old 07-13-2008   #9
brando
Drives: gutlass
you should also change your thermostadt temp sensor as that will soon go. just a sugestion
