Old 08-15-2008   #1
Fuel Cut #3
92 TSI AWD 5spd
The car hits fuel cut. I know it's fuel cut. It even fuel cut on the dyno at the last dyno day. The car stopped hitting FC, found out there was a big boost leak before the maf, once it was fixed it hits FC again. Sounded like one or two smallish boost leaks from the throttle body area also.
I notice when it hits FC the wideband is like at 12.8
WHY does this happen?
Fresh 6 bolt
14B (15psi)
AFPR at stock FP
GM MAF/MAFT in blow through
"fuel cut" switch is "off"
FMIC
255HP
Disconnected FIAV coolant lines
