Old 09-13-2008   #1
TurboDomestics
TurboDomestics's Avatar
A bunch of stock dissum parts and 2g talon part out.
I am parting out a 95 tsi awd.
Trans is gone and engine is gone, but i still have most body parts and suspension. Just ask and ill see what I have.
Ill let the whole car go as is for $250. Perfect for that awd sypder swap, or any 2g awd conversion because the entire rear suspension, gas tank and rear end is there.
Heres a brief list of stock parts I have:
-Perfect side view mirrors (black) $40 each Real Clean!
-2g cylinder heads, complete from cams to valves, need new valves. I have 2 $60 each
-Stock Valve cover in good condition, could use a good cleaning. $40
-T-25 turbo needs a rebuild. $40
-Small 16g with 2g manifold and o2 housing. Needs a rebuild. $100
-1g 22 spline transfer case $100
-2g oil filter housings. $20 each
-2g turbo radiator. $30 with fan $35
-2g ISC motor. $40 (fix that idle problem!!)
-2g ps pump $20
-2g coil packs. $50 each
-I also have 3 or 4 spare 7 bolt short blocks. I dont know what condition they are in, but all are rebuild able. $100 for a short block
-Anything else you need any random sensor or misc part, JUST ASK!! I probably have one laying around somewhere.
If you need something email me at CharlieM_99@hotmail.com or pm me here and ill get back to you asap!
or just call/text my celly 612 703 1186
HELP ME CLEAN OUT MY GARAGE AND PAY FOR BOOZE!!! I mainly want to clean out my garage and help out some fellow dsm'ers not make a fortune!!
4G63 0, Charlie 3
Old 09-17-2008   #2
xheero
Re: A bunch of stock dissum parts and 2g talon part out.
im looking for the entire unit of the rotors, wheel bear, control arms and driver side axle? got them? n will the 95 parts fit the 99 eclipse gsx model? is it also abs?
xheero is offline   Reply With Quote
Old 09-23-2008   #3
stickyphoenix
The Wanderer
stickyphoenix's Avatar
Drives: '95 Eclipse GSX
Send a message via AIM to stickyphoenix
im still looking for that mani. please lemme know if its still for sale.
stickyphoenix is offline   Reply With Quote
Old 09-24-2008   #4
wants to be sideways...
123abc's Avatar
Drives: Loud cars
I'm looking for one of the front hub/wheel bearing assemblies. Has to be in great shape still. Gotta replace the left front wheel bearing in my Avenger and I'm cheap.
Originally Posted by Matt D.
Originally Posted by 93GSX5SD
Old 09-28-2008   #5
TurboDomestics
Sorry, someone is going to pick up the rolling shell later this week. So i dont want to take out stuff that will make it not rol..
4G63 0, Charlie 3
Old 09-28-2008   #6
Can I get the stock drivers side motor mount? I just need the insert, not the whole thing. I can give you an empty motor mount to replace it if you want.
