Old 09-23-2008   #1
TsiEagleTalon92
TsiEagleTalon92's Avatar
Drives: 2022 Hyundai Palisade
Questions/ Possible problems
One of my cars have been sitting for 1.5 years due to it being broke. I am finally getting around to fixing it little by little.
I just got a new alternator and plugs put in it and all my fluids are good. The question I have is that I have a loud hissing type sound coming from the intake air filter. I have no idea what the cause of it is and I don't think to well that it can be good.
One other thing that I noticed while letting it run a bit is that my oil pressure gauge is not moving a bit and it always used to work.
My last thing I can think of for now is that It always had a tendency to sputter once and a while but now it is doing it pretty bad. If it's cold it'll do it and eventually clear itself out but if you step on the throttle it is hiccups a lot and the RPMs will not go past 4500. Also it seems as tho at an idle when cold it doesn't want to stay running but it does.
I have gas that has been in the tank just as long as it has been sitting and I have not changed my wires yet (picking up soon) How many vac lines are there so I can check those since I heard a long time ago I might have bad vac. Vac lines don't just come from behind or underneath the intake manifold do they? if they do it shouldn't be hard to find then.
Thanks Guys.
