Old 09-27-2008   #1
HiImBrian
HiImBrian's Avatar
Drives: the girls crazy
power converter question
So I've got some big led neon tubes and a few black lights that are all made to be hooked up to a car battery. Well since I've moved out of my ricer stage and recently moved into a new house, I'd like to mount some of these on my walls so we can get a little dance party action goin on. I did a little google-ing on power converters and what I need in order to plug these into an outlet.
Basically I need a 120-12 volt converter, but what I found was some of these converters look very much like cell phone chargers. So, I'm wondering if there is any sort of charger that might work as a converter. Or what kind of converter I should go about using.
I'd like something I can wire all the neons into and then plug in.
pics or gtfo
Old 09-27-2008   #2
twack
It was a auto get over it
twack's Avatar
Re: power converter question
start looking at the plugins at the ratings on them and what they can or cant put out, most say on them
Old 09-27-2008   #3
HiImBrian
HiImBrian's Avatar
How do I know what to look for? I've just got some random neons?
pics or gtfo
Old 09-27-2008   #4
twack
twack's Avatar
o you dont know what the neons NEED, dont really gt an answer for ya and you really dont want to start a fire so ill pass this on to someone else, unless you just want to try out and see what happens
Old 09-27-2008   #5
Febo
Manic Narcissistic
Febo's Avatar
Drives: IS300
probably around 12vdc and 10amps. You can wire these neons directly into your vehicles wiring. So just get a 12vdc converter that has about 10amps
Old 09-27-2008   #6
HiImBrian
HiImBrian's Avatar
http://www.summitsource.com/product_...oducts_id=6807
pics or gtfo
Old 09-27-2008   #7
Yea anything with 12v dc output will work, those black bricks that plug in are AC/DC converters and step down the voltage. They should usually say what the output voltage is.
Then to hook it up you just need to cut off the plug and use the two wires for positive and negative to hook up to the lights.
Old 09-27-2008   #8
Febo
Manic Narcissistic
Febo's Avatar
Drives: IS300
That converter should work just fine Brian. I dont see a real problem with you starting anything on fire with neon lights.
Old 09-28-2008   #9
xveganxcowboyx
Wanker
xveganxcowboyx's Avatar
Drives: 95 M3
850 milliamps may not be enough. I have no idea what the amperage requirements for those neons are. You might try grabbing one from Ax-Man. Look for 12-14 volt output and as many amps as you can.
A computer power supply might be a good possibility as well.
Old 09-28-2008   #10
4g63tcrazy
is Nashty
4g63tcrazy's Avatar
Drives: Cyborg from Japan
I have an AC/DC converter sitting in my room. Worked great for when I put neons up. I'd sell it to you for cheap if you want. PM me if interested.
-1990 Mitsubishi Cyborg 4WD-
Old 09-28-2008   #11
HiImBrian
HiImBrian's Avatar
So you used it to plug car neons up to a wall outlet? My buddy works at a guitar place and he's gunna see if he can get me a couple like the one in the link. If those don't work I'll let you know How much is cheap? I've seen these go from $3-300
pics or gtfo
Old 09-28-2008   #12
4g63tcrazy
is Nashty
4g63tcrazy's Avatar
Yeah I used to have a neon rope for a car but I wanted it for my room so I bought the converter. I bought if for $90 so how about 40 shipped?
Old 09-28-2008   #13
HiImBrian
HiImBrian's Avatar
Wow no thanks. I'd rather just get that simple $3 one.
pics or gtfo
