Old 09-28-2008   #1
Constant_Project21
Constant_Project21's Avatar
Drives: E36
Coil on plug
Was just browsing an ebay motors page, that had a built 2g for sale. I noticed the coil on plug ignition system, and that it is on most high powered dsm's. I know the basic premise of the coil on plug system, but want to know some more about it. I am planning on building a built 1g soon and wanted to know if the COP system was worth the money. If you got links that would be great.
Thanks.
Old 09-28-2008   #2
wants to be sideways...
123abc's Avatar
Drives: Loud cars
Re: Coil on plug
If you do your research and know what you're doing, a cop setup can be built for very cheap. I built mine out of 4 2.7L intrepid coils and my own base plate.
Cost me no more than 50 bucks total and couldn't be happier.
http://www.dsmtuners.com/forums/arti...tup-cheap.html
Originally Posted by Matt D.
Originally Posted by 93GSX5SD
Old 09-28-2008   #3
craig
wants to kick mark
craig's Avatar
Drives: Battery with wheels
Re: Coil on plug
unless your running over 600hp the stock coil is fine. cop system is alot more looks. It does make it look real clean though
Old 09-28-2008   #4
Re: Coil on plug
+1 for keeping the stock coil, why spend the money on COP if you dont have to?
Old 09-28-2008   #5
twack
It was a auto get over it
twack's Avatar
Re: Coil on plug
i like my cop, thats all i have to say
Old 09-28-2008   #6
123abc's Avatar
Drives: Loud cars
Re: Coil on plug
Compared to the stock wires and coil setup I had before, I noticed better throttle response, and much smoother power. So I would look at it more as an alternative to upgrading to thicker wires.
Old 09-28-2008   #7
Febo
Manic Narcissistic
Febo's Avatar
Drives: IS300
Re: Coil on plug
Wow, that link, he has the worst looking engine bay for having a cops set up. I mean, stock FPR? Really?
Old 09-28-2008   #8
123abc's Avatar
Drives: Loud cars
Re: Coil on plug
I have a 14b stock injectors fuel pump and fpr, what's so wrong with that?
Old 09-28-2008   #9
twack
twack's Avatar
Re: Coil on plug
everything
Old 09-28-2008   #10
Re: Coil on plug
Stock FPR is fine unless you have 2 fuel pumps or some crazy single external fuel pump.
Old 09-28-2008   #11
Febo
Manic Narcissistic
Febo's Avatar
Drives: IS300
Re: Coil on plug
Ohhhh, nothing at all...... Just seems a waste of a COP setup is all.
Old 09-28-2008   #12
twack
twack's Avatar
Re: Coil on plug
im glad we all have to do things the same
Old 09-28-2008   #13
Febo
Manic Narcissistic
Febo's Avatar
Drives: IS300
Re: Coil on plug
Its scary outside of the box
Old 09-28-2008   #14
twack
twack's Avatar
Re: Coil on plug
very, i bring my flashlight and blanket
Old 09-28-2008   #15
Re: Coil on plug
I had that setup for like a day, sputtered and misfired like crazy, wanna say had one bad coil ( I couldn't find specs to test the coils). Looked cool though! I'd prefer to buy new coils and do it, for piece of mind. Why even bother with used shit.
Old 09-28-2008   #16
twack
twack's Avatar
Re: Coil on plug
cause you can get lucky and grab a bunch cheap you just have to find the testing specs
Old 09-28-2008   #17
Constant_Project21
Drives: E36
Re: Coil on plug
So there's a mixed review when it comes to the COP set-up. From what it sounds like, is that if I am not pushing 600+ then there is no use for a COP system, other than cosmetics. I think it makes it look outstandingly clean, and that seems to be the consensus. But I guess I will have to make that choice once I come to that point.
Old 09-28-2008   #18
123abc's Avatar
Drives: Loud cars
Re: Coil on plug
I bought my coils off ebay. Wired them up according to the diagram in that tuner's link, and she fired up first try. Haven't had a single issue and have been loving it.
Old 09-28-2008   #19
Febo
Manic Narcissistic
Febo's Avatar
Drives: IS300
Re: Coil on plug
basically
Old 09-28-2008   #20
EclipseGST
EclipseGST's Avatar
Drives: Short Bus
Re: Coil on plug
Honestly COP setups do absolutely nothing different than the stock coils without a CDI box...
The only benefit is no spark plug wires and it makes the engine look a little cleaner, unless do you it half assed with sheet metal. They are still running wasted spark (where the spark fires on 2 cylinders at a time) and the spark is the same as if you are only running 2 coils (stock).
Now if you want the real advantage, get a MSD or AEM CDI box and wire the coils individually. Then you will see a stronger spark. Even the stock coils with a CDI box will be better than a COP setup without a CDI box.
Dustin, I'm willing to bet that the reason you saw an improvement is because you had shitty wires, coil pack, plugs, or all of the above.
Now in some peoples cases that have a SMIM, no place to mount the coil pack and dont want the wires, sure... It makes it look better, but thats about it.
For the normal person that does this, its not going to cost you $50, unless you cut a piece of sheet metal with a dremel and half ass it together. I personally would never put the setup in that link on my car. Just looks like shit. I'd much rather machine a plate or buy a JM Fab plate for $80 like I did here, although I have an AEM CDI box to control it...
Originally Posted by shoutbox
