Old 10-08-2008   #1
OmgAwd
OmgAwd's Avatar
Drives: 1992 Eagle Talon TSi Awd
Replacing Oil Pan on 1G TSi
Should i use a FELPRO gasket, RTV, or both?
OmgAwd is offline   Reply With Quote
Old 10-08-2008   #2
x-pride
x-pride's Avatar
Re: Replacing Oil Pan on 1G TSi
RTV is the only way to go! No gasket needed. Make sure you don't put a long bolt on the oil pan hole under the timing belt.
Old 10-08-2008   #3
Speedfreak
Drives: four tires
Make sure your surfaces are very clean and dry(brakeclean). Then make sure your RTV is the correct stuff for oil sealing.
Old 10-08-2008   #4
HiImBrian
HiImBrian's Avatar
Drives: the girls crazy
Use A LOT of rtv (ultra grey/black) and make sure you torque the bolts to spec.
pics or gtfo
Old 10-08-2008   #5
torque spec is like 15 ft-lbs, very light!
Old 10-08-2008   #6
It's a lot less than 15 ft/lbs, it's something inch/lbs.
Old 10-08-2008   #7
And use ultra black on it, that works the best.
Old 10-08-2008   #8
HiImBrian
HiImBrian's Avatar
You're definitely right, it's inch/lbs for sure. Id find the torque specs online just to be sure though. I remember it's basically a hair more than finger tight.
pics or gtfo
Old 10-09-2008   #9
OmgAwd
OmgAwd's Avatar
That's why I asked. Two are stripped out because of the previous owner.
Old 10-09-2008   #10
Doh! Yes, way lighter, you're right!
Old 10-09-2008   #11
Scheides wouldn't know, his torque wrench is busted anyway.
Old 10-09-2008   #12
^lol.
Should he be careful to how much he is putting on too, don't want a big goop of it on the inside of the oil pan.
Old 10-09-2008   #13
You want to use enough so you get a nice solid thick bead, but not so much it squeezes out all over the place. Be sure to also go surround all the bolt holes.
Old 10-09-2008   #14
OmgAwd
OmgAwd's Avatar
Thank you. Can i get RTV at any auto parts store?
Old 10-09-2008   #15
A nice bead is all you need. Something I have done myself is lay a bead, and then gently spread it out on the surface of the pan leaving a nice layer, not too thin. And DO NOT get a lot of RTV on the bolts, you can hydrolically lock the bolt and possible screw the threads up more. If some are stripped, try just running a proper tap (M6x1.00 I think) and try threading in a bolt. If it seems to feel good, just let it be then. Might even have to helicoil some of the holes.
Old 10-09-2008   #16
Also, ULTRA BLACK is the best (quoting a Permatex employee) RTV of all the kinds Permatex makes, and is the best for this application.
Old 10-09-2008   #17
Yup.
Old 10-09-2008   #18
AwdGSX13
AwdGSX13's Avatar
Drives: Cars
Ultra Black RTV FTW!
-Matt
'94 Eagle Talon TSI AWD
'06 Acura TL
Old 10-09-2008   #19
CarPsyco84
CarPsyco84's Avatar
If the stripped holes are right next to each other your probly going to wanna try to fix them, if their not it "might" not leak.... depends on where it is too, if its on a corner or just the side.
-When in doubt, Moar RPM.
Old 10-15-2008   #20
iceminion
iceminion's Avatar
my $0.02:
use a straight edge to verify that there are no bends in the pan, pound any dents flat.
I have heard good things about "The Right Stuff" as a matter of fact, my goodyear has stopped using black silcone because this stuff outperforms it in every area (we cannot have customers come back, not good for business)
Personally I recommend 3M Weather Stripping Adheasive, nasty nasty stuff!!! and it dries in under a minute and is extremely sticky!!! it is less flexible then RTV when cured, so when removing the pan it comes off quite a bit easier.....
building a 3000GT AWD Turbo.
