Old 10-19-2008   #1
TsiEagleTalon92
TsiEagleTalon92's Avatar
Drives: 2022 Hyundai Palisade
Starts like ass, sputters and runs rich
I have had my Eclipse GS N/A sitting for over a year and a half and finally got it running again. It takes a few too many cranks to get it started, but when it does run it sputters while driving and when I get close to 4000rpms then it really sputters and sometimes cant make it over that. When it is cold you are not able to get it over 4000.
My thought is that my fuel pressure regulator is bad and is either not letting fuel return to the tank and is getting shot through the injectors in turn making it run rich and starting like crap.
Any thoughts as to what might be the problem?
Old 10-19-2008   #2
Febo
Manic Narcissistic
Febo's Avatar
Drives: IS300
Re: Starts like ass, sputters and runs rich
did you put fresh gas in it?
Old 10-19-2008   #3
Fresh spark plugs and wires?
Old 10-19-2008   #4
TsiEagleTalon92
Fresh fuel with sea foam, iso heat.
New plugs, wires, Recharged filter. fuel filter was replaced before it broke.
Old 10-19-2008   #5
Timing/timing belt correct?
Old 10-19-2008   #6
TsiEagleTalon92
yup everything is in order the timing belt has about 20000 on it if that.
I think my MPI relay is bad, my pump doesn't receive power so I have it hardwired like my talon and that thing starts just fine.
Old 10-19-2008   #7
TsiEagleTalon92
before I started doing any real work on the car it started just fine but when I dug into all the things I needed to do to it it just stopped starting correctly.
Old 10-19-2008   #8
OmgAwd
OmgAwd's Avatar
Drives: 1992 Eagle Talon TSi Awd
O2 Sensor?
OmgAwd is offline   Reply With Quote
Old 10-19-2008   #9
TsiEagleTalon92
swapped it with another spare I have with no change so I swapped back.
Old 10-19-2008   #10
munchgsx
munchgsx's Avatar
Drives: 2004 Corvette M6 F45
Compression Test
Old 10-19-2008   #11
TsiEagleTalon92
if it comes down to it I will do that but I don't believe that will be the source.
Old 10-19-2008   #12
Febo
Manic Narcissistic
Febo's Avatar
Drives: IS300
coil pack? Or maybe when you put the fresh gas in you loosend up some sludge and clogged your Fuel injectors?
Old 10-19-2008   #13
TsiEagleTalon92
coil pack was replaced about a year before it sat. I had one other person say I may have clogged injectors. What is the possibility of a clogged filter or a bad FPR?
Old 10-19-2008   #14
SnoEclipse
Drives: 07 Eclipse GT
I know that I'm not being helpful here but your topic headline reminds me of an Ex......
Old 10-19-2008   #15
TsiEagleTalon92
That gave me a good chuckle. doesn't always have to be an ex for some. (poor guys)
Old 10-19-2008   #16
Febo
Manic Narcissistic
Febo's Avatar
Drives: IS300
Well filter is probably more likely than your injectors as it would of caught it all first I guess. But FPR.... eh... I wouldnt think you would have these issues. It sounds like a lack of fuel or spark versus running pig rich. Just IMO. Im just thinking with it sitting for a year or so, unless you drained the tank before it sat the gas easily varnished and you may have just broke all that up with your mix of good gas, sea foam, and ISO Heat.
Old 10-20-2008   #17
TsiEagleTalon92
Well it a for sure running very rich. You can smell it a ton in the exhaust and all four of my plugs are already covered in soot. I have a buddy with a 91 turbo that let his sit for a while like a few months and had that but it cleared up in 3 days.
Old 10-20-2008   #18
brando
Drives: gutlass
COIL PACK!!! i would replace it but dont get a msd one.
Old 10-20-2008   #19
TsiEagleTalon92
Nothing is going in this stock car except stock parts for sure. That would sure suck if its a second bad coil pack... That just doesn't seem right.
Old 10-20-2008   #20
TsiEagleTalon92
switched out coil pack with the talon's with no change. I am going towards FPR or bad fuel. A guy at work told me to take off the vacuum hose to the FPR and see if fuel comes out but he did not tell me what that would indicate.
In my eyes I believe I am seeing too much fuel for the car to bear.
