Old 10-28-2008   #1
slowboy101
slowboy101's Avatar
Drives: 91' Eagle Talon TSI
EGT and AFC troubles
Ok heres the deal when Im cruising down the high way at about 75 my EGT is at about 13 and ounce I hit 80 it would be at 14 when I let of the gas it dramastically drops to 12 my afc is a NEO and I have it set at
High throttle: +15 thru all RPM
Low throttle: +5 thru all RPM
for mods I have fabracated intake manifold,550RC injectors, 2g fuel rail, 225 welbro fuel pump (I think) then 3in catback. and 2g mas
slowboy101 is offline   Reply With Quote
Old 10-28-2008   #2
Re: EGT and AFC troubles
So whats the problem?
Old 10-28-2008   #3
EGT's should be called timing gauges. Have you had your car tuned?
Old 10-28-2008   #4
You need a logger. Otherwise, you have no idea what's going on with knock, afr, etc. Typically you do not flat-line the AFC like that.
Old 10-28-2008   #5
dsm9sec
Drives: ... More than you can afford, pal
I swear you guys with new gauges need to search around for normal conditions. This is a normal thing.
Swanny's right you do need a tune though.
dsm9sec is offline   Reply With Quote
Old 10-28-2008   #6
Neo doesn't work on Karmen cars, unless you recently sent it back in to be updated.
Old 10-28-2008   #7
slowboy101
slowboy101's Avatar
k thanks guys
Old 10-28-2008   #8
slowboy101
slowboy101's Avatar
dose anyone have a wideband i can barrow ill pay some money to barrow it
Old 10-28-2008   #9
dsm9sec
DB's got a wideband with a tail pipe sniffer lol.
Old 10-28-2008   #10
Get your car dyno-tuned. Its worth the cost.
