Old 11-06-2008   #1
GnArKiLl
GnArKiLl's Avatar
car keeps stalling.. and im stumped!
my 93 talon has been having a problem ever since i finished the 5spd swap... mods are fic 650's, pte 50trim,3"gm maf,255 fuel pump,afpr,boost set to 15 for now.. the problem is the car wants to die everytime i stop, if i push the clutch in befor the rpm's settle it will die. if i take it out of grear and coast w/o the clutch in it will die every now and again, but nomatter what if i take it out of gear and coast up to my stop the rpm's drop to about 500 and then pick up... i have checked for boost/vac leaks and found nothing. i changed the closed throttle switch. still nothing.... what else am i missing???
Old 11-06-2008   #2
Re: car keeps stalling.. and im stumped!
Bad idle motor? Is the MAF after the BOV? If the car is fully warmed up and just idling while sitting still, do the RPMs go down when you push the clutch in?
Old 11-06-2008   #3
You said nothing about fuel control in your mod list, what are you using to tune it? Are you just using the MAFT? If you are still using the auto ECU, remember that it is programmed for 390cc injectors. What fuel pressure are you set for with the afpr (with the vacuum line off)?
Old 11-06-2008   #4
GnArKiLl
GnArKiLl's Avatar
yes the maf is after to bov.. and yes the rpms go up and down with the clutch..
im using the maft and safcII.. and im using a 92 5spd eprom, also have it set to stock 5spd fuel pressure..
also i do have idle surge..
