Old 11-08-2008   #1
v8klla
v8klla's Avatar
MAPerformance Year End Clearance Sale / Pricing at or below cost on most items!
Sorry about the formatting here, I just couldn't find a way to make it less cluttered lol. However, if you spend the time to look through this it will definitely be worth your while Please contact us for pricing and availability!
ACL 1T1853 ACL Thrust Washers / Mazda B6 & BP Engines 1.00
ACL 5M1857 ACL Main Bearings / Toyota 2ZZGE 1.00
ACL 5M8092H ACL Race Main Bearings (Toyota/Lexus 1UZFE/2UZFE) 1.00
ACL 8B8091H ACL Race Rod Bearings (Toyota/Lexus 1UZFE/2UZFE) 1.00
ACT MB1-HDR4 ACT HD (2100) Clutch Kit / 4 Puck Solid Disc / DSM 1.00
AEM 21-412C AEM Cold Air Intake / B Series Honda 1.00
AEM 21-412P AEM Cold Air Intake / B Series Honda (Polished) 2.00
AEM 25-103B AEM High Volume Fuel Rail / B Series Honda 1.00
AEM 30-3000 AEM Water Injection Kit with 1 Gallon Tank 3.00
AEM 30-3001 AEM Water Injection Kit, 5 Gallon UNIVERSAL 1.00
APE 145-M005 Apexi GT Spec Downpipe / Evo 1.00
APE 147-KM02 Apexi N1 Downpipe / 2g FWD DSM 1.00
APE 155-A007 Apexi Silencer for GT Spec, N1 Turbo, Int. Dunk (115mm) 1.00
APE 161-KM01 Apexi N1 Catback Exhaust / 2g AWD DSM 3.00
APE 161-KM03 Apexi N1 Exhaust Mitsubishi Eclipse 1990 - 1994 GSX 70mm-74.7mm; 115mm 1.00
APS APSWRX-FMI/R4B-OB APS DR725 Front Mount Intercooler / Black *Open Box / Display Item* 1.00
APS WRX-TMI/06-OB SR 375 Dual Entry Top Mount Intercooler System (WRX) *Open Box / Repaired* 1.00
ARP 208-5401 ARP Main Studs / Honda Prelude - H22A, H23A 1.00
ARP L19-6 ARP Extreme Duty Head Studs / 6 Bolt DSM 19.00
ATI 917991 ATI Super Damper / WRX & STi 6.00
ATI 918250 ATI Damper / EVO 2.00
ATI 918251 ATI Damper / DSM 1.00
AUT 3211 Autometer Replacement Bulb and Socket / No. 168 / 4.9 Watt 1.00
AUT 3222 Autometer Tubing and Line Kit / 10' Long 1/8" Diameter 1.00
AUT 3284 Autometer Replacement Bulb and Socket *Replaces bulbs 161, 193, 194, and 168 only 2.00
AUT 4304 2" Ultra Light Mechanical Boost Gauge 0-35 1.00
AUT 5703-M Autometer Phantom Boost Gauge 2-1/16"-52mm(Metric) 1.00
AUT 5704 Phantom Series / Mechanical Boost Gauge / 0 - 35 PSI 1.00
AVI AC.MM.001 Avid Engine Mount Kit for B-series (Cable Trans.) 1.00
AVI AC.MM.004 Avid Performance Upgrade Mount Kit for 92-95 Civic/93-97 Del Sol (2 Hole style mount) 1.00
AVI AC.MM.007 Avid Performance Upgrade Mount Kit for 96-00 Honda Civic / Acura 1.6 EL 1.00
AVI AC.MM.015 Avid Performance Upgrade Mount Kit for Mitsubishi EVO 8/9 (3 piece) 1.00
AVI AC.TS.002PRO Avid Pro-Series Chromoly Traction Bar Kit 1.00
BC0040 Brian Crower Dual Valve Springs & Retainers with Seats / K20A & K20Z 1.00
BC0050 Brian Crower Valve Springs & Retainers / K20A3 & K24A 1.00
BC0051 Brian Crower Forced Induction & NA Street Stage 2 Camshafts / K20A3 & K24A 1.00
BC0102 Brian Crower Stage 3 Camshafts / DSM 2.00
BC0111 Brian Crower Stage 2 Camshafts / Evo 8 2.00
BC0112 Brian Crower Stage 3 Camshafts / Evo 8 2.00
BC0121 Brian Crower Stage 2 Camshafts / Evo 9 MIVEC 1.00
BC0600 Brian Crower Valve Springs & Retainers / Subaru EJ Series 1.00
BC0601 Brian Crower Stage 2 Camshafts / EJ205 WRX 2.00
BOR 140075 Borla SS Catback Exhaust System / '04-'07 STi 1.00
BOR 14978 Borla SS Catback Exhaust System / '02-'05 WRX 1.00
CLE CB-1643P-.50MM Clevite Rod Bearings / 2g DSM & Evo / .50mm 4.00
CLE MS-2039P-.50MM Clevite Main Bearings / 95-96 DSM / .50mm 1.00
CLE TW-5885 Clevite Thrust Washers / Toyota 1UZFE 1.00
COS KK3672 Cosworth 4G63 CNC Ported Big Valve Cylinder Head / Evo 8 1.00
COS PR7427 Cosworth Mitsubishi 4G63 (EVOVII-VIII) High Performance Main Bearing Set 1.00
DEF DF03301 Defi Triple Meter Hood for New Age Impreza 1.00
DNP 44T40 DNPerformance 44mm to 40mm Wastegate Adapter (No Clamp) 1.00
EAG 1835041772 4340 Crnk Stck B18a/b-B20b/z(LS/CRV) 4.00
EAG 2439375900A6 Mitsubishi 6-bolt 100mm Crank 2.00
EAG CRS5394A3D H-BEAM Connecting Rod B18a/b-B20b/z(LS/CRV) 4.00
EAR 820111ERL Earl's Hose End, Swivel Seal, Straight, -10 AN Hose to Male 3/ 8 in. NPT 2.00
EAR 820166ERL Earl's Hose End, Swivel Seal, Straight, -6 AN Hose to Male 3/ 8 in. NPT 1.00
EIB 2820.140 Eibach Pro-Kit Lowering Springs / SRT-4 1.00
EIB 6010.140 Eibach Pro-Kit Lowering Springs / 1g AWD DSM 1.00
EIB 7710.140 Eibach Pro-Kit Lowering Springs / '02-'03 WRX 1.00
EIB 7718.140 Eibach Pro Kit Spring Kit 2008 Subaru STi 1.00
ENE 16.1102G Energy Suspension Trans Shifter Stabilizer Bushings / Black / 93-97 Honda Del Sol 1.00
ENE 9.13101G Energy Suspension Tie Rod Dust Boots / 1g AWD DSM 1.00
EXE 08950B Exedy Stage 2 Clutch Kit / B Series Honda 5.00
EXE FF02 Exedy Lightweight Flywheel / STi 2.00
EXE FH02SD Exedy Hypersingle Clutch Kit with Flywheel / STi 1.00
EXE HH03SD Exedy Hypersingle Clutch Kit with Flywheel / RSX & Civic Si 1.00
EXE MH01SD Exedy Hyper Single Plate - Pull Type / 2655 Clamping Load ; ( INCLUDES LIGHTWEIGHT FLYWHEEL ) fo... 2.00
EXE MM022HD Exedy HD Twin Disc Clutch Kit / Evo 3.00
FEL VS50434R Felpro Valve Cover Gasket Set / DSM 1.00
FER F1519P Ferrea Exhaust Valves / 1mm Over / EJ257 (Set of 8) 1.00
FER F1524P Ferrea Intake Valves / 1mm Over / EJ257 1.00
FID 161657 Flywheel for Twin Disc Clutch Kit / 6 Bolt FWD DSM 6.00
FID 311483 Fidanza 4.3 Clutch Kit / Subaru 2.0L WRX 1.00
FID 810020 Fidanza Short Shifter / WRX 2.00
FID 894030 Fidanza Short Shifter / SRT-4 3.00
FID 961996 Fidanza Cam Gear / 4g63 / Red (Pair) 1.00
FLU 630701 Engine Dampner 4G63 3.00
FOR FMUNOS Forge UNOS Manual Boost Controller 1.00
FOR FPMLSSEVO Forced Performance EVO Oil Supply Line (-4 SS Line / 12mm|10mm Banjo Fittings) 1.00
GFB 5701 Go Fast Bits Whistling Trumpet 1.00
GM 3MAF GM Impala SS 3" MAF Sensor 1.00
GRE 11900471 Greddy 28-35mm BOV Outlet for Type R BOV 1.00
GRE 15931600 EVO 9 V-Manage Kit 1.00
INJ SP6062BLK Injen 2007+ Mazdaspeed3 2.3L Cold Air Intake Manual Transmission with MR Technology / BLACK 3.00
INN 3806 Innovate LM-2 Wideband Kit / OBDII Compatible 1.00
INV HS03ML8DPP Invidia SS Downpipe / Evo 2.00
INV HS03ML8G2T Invidia G200 Cat Back Exhaust System / Evo 1.00
Chris Carey, President
Modern Automotive Performance
P: 763-545-3800
E: chris@maperformance.com
Old 11-08-2008   #2
v8klla
v8klla's Avatar
Re: MAPerformance Year End Clearance Sale / Pricing at or below cost on most items!
KOY R2024 Koyo Aluminum Radiator / 2g DSM 1.00
KYB 334470 KYB OE Replacement GR-2 Excel-G Right Side Strut 04-05 Subaru WRX-STi / 05-06 Impreza(Exc Outback) 1.00
KYB 334471 KYB OE Replacement GR-2 Excel-G Left Side Strut 04-05 Subaru WRX-STi / 05-06 Impreza(Exc Outback) 1.00
KYB 73403X KYB AGX Adjustable Shocks / Struts (Complete Set for '02-'03 WRX) 2.00
MAF 050DSMTRANS1G MAFT / 1g DSM 1.00
MAH EVO367366I13 Mitsubishi 2.0L 93-02 Eclipse 1.00
MAH EVO367385I13 Mitsubishi 2.0L 93-02 Eclipse 1.00
MAH MIT367366I13 Mitsubishi 2.0L 88-92 Eclipse 21m 1.00
MAH WRX209917I22 Subaru EJ 25, 99.5 mm Bore 8.5/1 Comp 2.00
MAH WRX209937I22 STi, Legacy GTI 100mm Bore 8.5/1 Comp 1.00
MAP 23SB-S1 MAP 6 Bolt 2.3l Shortblock / Stage 1 (Wiseco / Eagle) 1.00
MAP 23SB-S2 MAP Stage 2 2.3l Shortblock / *See Invoice #1682 for included items 1.00
MGN 45423 Magnecor Competition Spark Plug Set Evo 5-8 1.00
MIC 3010 Mickey Thompson ET Drag Tire / 22x8x13 4.00
MIC 3019 Mickey Thompson ET Drag Tire / 22x8x15 4.00
MSD 5900 MSD Blaster Ignition 1.00
OEM 6B24C-.5 OEM 6 Bolt 2.4l Crankshaft / .5mm Undersize 2.00
OEM 7B20C OEM 7 Bolt 2.0l Crankshaft / Standard 2.00
PE TH650F Power Enterprise Top Feed 650cc Fuel Injectors 4.00
PER ASM-INT-600BK Blow Off Valve Kit Recirc EVO VIII/IX - BLACK 1.00
PER ASM-INT-720 Perrin Performance Electronic Boost Control Solenoid 1.00
PER PEP-BDY-105 Perrin Performance Shorty Antenna 2" Evo VIII/IX 1.00
PER PEP-EXT-200 Perrin Performance SS Downpipe / 3" / Evo 4.00
PER PEP-EXT-300BK Perrin Performance Catback Exhaust / Stealth / Evo 1.00
PER PEP-SUS-210 Perrin Performance Adjustable Endlinks / Rear / Evo 1.00
PER PSP-BRK-400 Master Cylinder Support Brace 02-07 Impreza 2.00
PER PSP-ENG-500BK Perrin Performance Radiator Shroud / WRX & STi / Black 1.00
PER PSP-EXT-206F Perrin Performance Downpipe / Front Section / '06-'07 WRX 1.00
PER PSP-EXT-206R Perrin Performance Downpipe / Rear Section / '06-'07 WRX 1.00
PER PSP-EXT-305BK Perrin Performance Sport Tone Exhaust / Single Tip / Stealth / WRX & STi 2.00
PER PSP-INT-200BK Short Ram Intake System WRX 2002+ / BLACK 2.00
PER PSP-INT-200BL Short Ram Intake System WRX 2002+ / BLUE 2.00
PER PSP-INT-200RD Short Ram Intake System WRX 2002+ / RED 1.00
PER PSP-INT-600BK Perrin Performance Recirculating Blow Off Valve / Black / WRX & STi 1.00
PER PSP-INT-600SS Perrin Performance Recirculating Blow Off Valve / Red / WRX & STi 1.00
PER PSP-SUS-100 Perrin Performance Front Swaybar / 22mm / WRX & STi 1.00
PER PSP-SUS-101 Perrin SWAY BAR FRONT 25MM (1") 02-07 WRX/STI 1.00
PER PSP-SUS-200 Perrin Performance Sway Bar / 22mm / Adjustable / WRX 1.00
PER PSP-SUS-205 Perrin Performance Sway Bar / 22mm / Rear / STi 1.00
PER PSP-SUS-207 Perrin Performance Sway Bar / 25mm / Rear / STi 1.00
PER PSP-SUS-208 Rear Sway Bar 25mm (1") Bar STi 4.00
PER PSP-SUS-210 Perrin Performance Rear Endlinks / 93-07 Impreza & WRX 2.00
PER PSP-SUS-215 Perrin Performance Endlinks / Rear / STi 1.00
PER PSP-SUS-400 Perrin Performance PSRS / WRX 2.00
POW 518PSL/R Powerslot Rotors / Up to 5/92 AWD DSM Front Pair 1.00
POW 583PSL/R Powerslot Rotors / 6/92+ AWD DSM Front Pair 4.00
POW 735PSL/R Powerslot Rotors / '04 STi Front Pair 1.00
POW 736PSL/R Powerslot Rotors / '04 STi Rear Pair 1.00
POW 772PSL/R Powerslot Rotors / 2g Rear Pair 3.00
PRT 13-1901-BL Prothane Motor Mounts (Black) 95-99 DSM 6.00
PRT 13-1902-BL Prothane Motor Mounts 90-94 DSM (BLACK) 3.00
PTE 071-1026 PTE 3" V-Band Clamp 2.00
PUN T35BSS Punishment Racing SS 5 Bolt T3 O2 Housing for DSM 1.00
SAM TB1524-RED Samco Sport VW Golf Mk4 / Beetle / Audi TT 180 / Seat Leon / Skoda Octavia Turbo Induction (Red) 1.00
SAM TB997-BLU Samco Sport Turbo Inlet Hose (WRX/STi) / Blue 1.00
SAM TCS209-BLU Subaru Impreza STi 01/02 (4) Turbo 1.00
SAM TCS271C-RED Samco Sport Coolant Hose Kit / SRT-4 / Red 1.00
SBR 0037 Slowboy Racing 2G DSM High Temp Manifold Spacer / Heat Barrier 1.00
SCA 65138289 Scat Pro 4340 Forged H-Beam Connecting Rods / Subaru WRX EJ20 1.00
SKU 305-06-0240 Skunk2 264/272 Camshafts / Evo 8 1.00
SKU 307-05-0290 Skunk2 Intake Manifold / 1992-93 Integra GS-R 1.00
SKU 311-06-0390 Skunk2 Dual Valve Springs & Retainers / 4g63 1.00
SPC 81250 SPC EZ CAM XR (12MM) 1.00
SPC 81260 SPC EZ CAM XR (14MM) 1.00
SYN SB001.4A Synapse HKS-style billet Aluminum flange for SB001 BOV 1.00
SYN SB001.5A Synapse Anti-stall valve kit for MAF cars with atmospheric discharge in billet Aluminum 1.00
SYN SB001.6A Synapse Synchronic BOV TiAL 50mm Adapter Flange in billet Aluminum 1.00
SYN SB001.8A Synapse Synchronic BOV SB001 Volkswagen, Audi 1" hose end adapter fittings only in Aluminum (2 p... 1.00
SYN WG001B.1 Synapse 40mm Universal 2-Bolt Synchronic Wastegate 1.00
TAY 98069 10.4mm Thunder Volt 50 Wires - DSM 1.00
TOK BU3532 Tokico Illumina Series Shocks for 2G AWD (Set of 2) (Front) 1.00
TOK BU3532-1 Tokico Illumina Series Shocks for 2G AWD (Single) (Front) 1.00
TOK BU3533- Tokico Illumina Series Shocks for 2G AWD (Set of 2) (Rear) 1.00
TOP CBSMI4 Topline Complete Block Gasket Set / 6 Bolt DSM 2.00
TOP CGSMI23 Topline Complete Gasket Set / 1g 7 Bolt DSM 3.00
TOP EPSMI4 Topline Freeze Plug Set(Nine 35mm Plugs / DSM 1.00
TOP HSMI23 Topline Head Gasket Set / 1g 7 Bolt DSM 1.00
TOP HSMI6 Topline Head Gasket Set / 6 Bolt DSM 3.00
TOP PAMI6T Topline Pistons with Rings Set / Standard Bore / 6 Bolt DSM 1.00
TOP WPMI23 Topline Water Pump / 1g 7 Bolt DSM 2.00
TUR FG-BOV-WRXSS Blowoff Valve Supersonic - Subaru WRX 01-05 1.00
TUR TS-0501-1011 Turbosmart 38mm Ultragate / Sleeper Black / 7psi Spring 7.00
TXS EVO8-FMIC TurboXS Front Mount Intercooler / Evo 1.00
TXS EVO8-FP TurboXS Downpipe / Evo 2.00
TXS WS08-RFL Turbo XS 2008 WRX RFL BOV 1.00
TXS WS-INTAKE TurboXS Short Ram Intake / WRX & STi 3.00
TXS WS-SBE TurboXS Stealth Back Exhaust System / WRX & STi 1.00
TXS WS-TBE TurboXS Turbo Back Exhaust System with Cat and Standard Muffler / WRX & STi 1.00
VIB 1636 Vibrant StreetPower Catback Exhaust / WRX & STi 1.00
VIB 18121 Vibrant Strut Tower Brace / 1g DSM / Polished 1.00
VIB 2178 Vibrant 2.5" O.D. Aluminum 90 Degree Bend - Polished 1.00
VIB 2744 4 Ply Re-Inforced Silicone Elbow Connector - 3" dia. - 90 deg. Elbow (BLACK) 1.00
VIB 2772 Vibrant Performance 4 Ply Reducer Coupling, 2.5" x 3" x 3" long - Black 1.00
VIB 2793 Vibrant Stainless Steel T-Bolt Clamps (Pack of 2) / Clamp Range: 2.66"-2.97" / Designed for 2.5"... 1.00
VIB 2794 Vibrant T-Bolt Clamp / For use with 2.75" couplers 1.00
VIB 2795 Vibrant Stainless Steel T-Bolt Clamps (Pack of 2) / Clamp Range: 3.28"-3.59" / Designed for 3" C... 2.00
VIS 7022 Visteon Aluminum Radiator w/Spal Fan / 2g N/T DSM 2.00
WHI KSR206 Whiteline Steering Rack Bushing Kit 1.00
WIL 150-9764K Wilwood PolyMatrix E Compound Brake Pads / Dynalite Single Front Axle 1.00
ZEX 82021 Zex Wet Nitrous System with 10lb Bottle / 55,65,75hp Jets Included 4.00
ZEX 82023P Zex Wet Nitrous System / Polished Bottle / 75,100,125hp Jets Included 1.00
P: 763-545-3800
Old 11-28-2008   #3
Chris, could you let me know the cost for prothane motor mount inserts for my 91 awd. Anyway that I can just get the inserts for the front and rear?
Old 11-28-2008   #4
v8klla
v8klla's Avatar
I think you can get just the inserts but at that point the Energy ones are cheaper, let me know which route you want to go!
P: 763-545-3800
Old 11-28-2008   #5
On order, thanks guys!
