Old 11-19-2008   #1
krayola46
Drives: 1G TSI
tbelt snapped
I bought a 92 talon tsi with no tbelt. must have snapped. wanting to know what I will all need to look at befor starting it. Im replacing the oil pump this weekend because it will not turn without lots of force. crank shaft spins. cam spins. everything but the oil pump so Im lead to believe thats my main issue. what could have all got messed up if the oil pump stopped, and the timing belt snapped? Im asking for a check list or any helpful info. thanks, Krayola
krayola46 is offline   Reply With Quote
Old 11-19-2008   #2
joem
Drives: 1991 Talon awd auto
Re: tbelt snapped
Pull head replace valves and check pistons.
Joe
Old 11-19-2008   #3
311evo
311evo's Avatar
Re: tbelt snapped
If the timing belt snapped while the car was running, its pretty much guaranteed you have some (at the least) bent valves.
a compression test would be in order i guess.
Old 11-19-2008   #4
Re: tbelt snapped
Congratulations on learning to post Now try the new members section and introduce yourself!
Old 11-19-2008   #5
Re: tbelt snapped
Pull head check everything, enjoy coloring.
Old 11-19-2008   #6
b00stcreep21
I hate everyone
b00stcreep21's Avatar
Re: tbelt snapped
You need a new head at least. End of story. If your oil pump spins like crap, get a new one. Have fun taking the front cover off in the car with balance shafts
Old 11-19-2008   #7
Re: tbelt snapped
The balance shaft on the oil pump shaft is probably what is bad, not the oil pump itself. You will need to replace the bearings for the rear balance shaft and probably the shaft itself. You can bypass that if you do a stubby balance shaft elimination. Your valves will be toast, so look for a new head or if you have plans for this one, put in oversized valves and get the head rebuilt now. Have someone knowledgable look at the pistons to see how big the dents are.
Old 11-20-2008   #8
Re: tbelt snapped
I've seen several oil pumps seize from lack of oil to the journal surface, especially on the cheap aftermarket ones. I always use only Mitsu front covers and I port out the oil feeds slightly. Good insurance.
Old 11-20-2008   #9
twack
It was a auto get over it
twack's Avatar
Re: tbelt snapped
ive used a topline oilpump for the last year and its been doing great. But regardless you just need to pull the head and post some pics and we can help ya from there
