Old 11-23-2008   #1
joem
Drives: 1991 Talon awd auto
Auto transmission ?
1991 Eagle Talon 2.0 turbo awd automatic transmision
Where is the temp sensor at on the auto trans or the wiring. Some one told me it was above the valve body so if thats the case I was thinking of rewiring it to a new temp sensor in like the tranny pan? Any ideas?
One more thing is there a recall or tsb on the shifters in these cars? I can pull on the shifter a little and the car will start to roll. The shifter handle is vary loose feeling like sloppy but all the bolts are tight on it?
Thanks
Joe
Old 11-24-2008   #2
joem
Re: Auto transmission ?
bump
Old 11-24-2008   #3
brando
Drives: gutlass
does it not work?
Old 11-24-2008   #4
joem
It does work for the most part but the shift pionts and lock up dont work right. The sensor reads -50* all the time.
Joe
Old 11-24-2008   #5
brando
Drives: gutlass
um truy just replacing the sensor. i cant really tell you where it is on your tranny i have only delt with a fwd 93 and another 90fwd but im guessing its gonna be tward's the back or next to the diff
Old 11-24-2008   #6
joem
No sensor on the back. I heard it was inside the trans above the valve body but I would like this to be confirmed. Then if it is so I need to find the wiring and put one in the trans pan and rewire it.
Joe
