Old 12-02-2008   #1
cman3000
Colin
cman3000's Avatar
100m Running Champion!
Drives: 90 Talon TSi AWD, 73 Datsun 240z w/Built L28
Switchin to E-85
Well, tried selling the Talon, but couldn't get what i wanted out of it, and i don't have the time to part it out as I'm in college, so i have decided to keep it. It was fun a hell to drive before the tranny took a shit, so i am excited to get it back on the road. I have decided i am going to switch to E-85, so i will try to document my progress on here. Also, i am still looking for a transmission, so if anyone has a slightly modified awd 23 spline they are trying to get rid of, let me know.
Existing Mods:
ENGINE BLOCK:
Balanced Crankshaft
ARP Main Studs
Eagle H-Beam Rods
Weisco 8.5 to 1 compression heat coated pistons
New High Volume Oil Pump
All new timing components. (pulleys, tensioner, etc.)
Unorthodox Underdrive Lightweight one piece Racing Pulley
Energy Suspension Prothane Motor/Transmission Mounts
Resurfaced block
Bored over and honed cylinder walls
Balance Shafts removed
CYLINDER HEAD:
Brian Crower 1mm Oversized Stainless Steel Valves
Ferrea Bronze Valve Guides
Brian Crower Springs and Retainers
Lightly Ported and Polished
Web 546/547 Street Grind Cams
Power Enterprise Kevlar Timing Belt
ARP Head Studs
OEM Mitsubishi Composite Headgasket
DRIVETRAIN:
John Shepherd Stage 3 Transmission
ACT Chromemoly Flywheel
ACT 2600 Pressure Plate
ACT Street Disc
New TOB
New Revised Clutch Fork
New Pivot Ball
New Factory Slave Cylinder
1/4" Longer Slave Cylinder Rod (for better ACT clutch engagement)
Three Speed Shatter Shield
Longer Flywheel Bolts with Bolt Plate
New 23 Spline Transfer Case
Rebuilt Driveshaft
New Carriage Bearings
4 Bolt Rearend with limited slip viscous differential
New Front Hub Bearings & Seals
BRAKES:
Front Baer Brakes with Slotted Rotors
New rear calipers with Slotted Rotors
Front & Rear Stainless Steel Braided Brake Lines
EXHAUST:
3" Stainless Steel Turbo Back Megan Racing Exhaust
2.5" Victory Performance Stainless Steel O2 Housing
Tial 40mm Waste Gate
FUEL SYSTEM:
Supra TT Fuel Pump
Re-wire fuel pump relay
8an braided fuel feed line from tank to fuel rail
Custom fuel filter setup
SX Adjustable Fuel Pressure Regulator
1200cc RC Fuel Injectors
MAF Translator 3" GM MAFS
INTAKE SYSTEM:
Bullseye T04B 50 Trim turbo (oil & water cooled, -10an oil drain)
Aluminum High Performance sheet metal Intake Manifold
2.5" Aluminum Intercooler piping
Tial 50mm BOV
2nd Gen Polished Throttle Body Elbow
32" x 8" x 3.5" Front Mount Intercooler
COOLING SYSTEM:
Alumium Mishimoto Radiator
Slim Fans (One Puller & One Pusher)
New Water Pump
New Hoses Braided
6an turbo coolant feed and return line
SUSPENSION:
K-Sport Fully Adjustable Front & Rear Coilovers
Suspension Techniques rear sway bar with Urethane Bushings
New Front & Rear Stabilizer Bar endlinks
RO_JA 18" Formula 5 lightweight wheels with 225/40/18 tires.
Megan Racing front and rear strut bars
AUDIO:
Pioneer head unit with detachable face and CD player with remote control
Polk Audio front, side, and rear speakers (6) Wired for rear mounted amp
GAUGES:
Autometer Phantom:
30psi Boost/Vacuum Gauge
Oil Pressure Gauge
Volt Gauge
Water Temp Gauge
EGT Gauge
ELECTRONICS:
New Battery
New Alternator
New Coil Packs
New Ignition Module
New Spark Plug Wires and Plugs(BPR7ES)
EPROM ECU with Keydiver Chip reprogrammed for the following; 8000 Rev Limiter NO Airflow CAP No Fuelcut Octane Reset Shift CE Light @ 7000 RPM Enhanced closed loop MAPS Knocksum Gauge 780cc injectors/264us deadtime 3” GM MAFT 850 RPM Idle 45 PSI AFPR 11.0:1 WOT A/F FED/AWD Locked Baro & Airtemp
Future Plans:
Get rid of the Keydiver chip and go with ECMLink
1000cc-1600cc FIC Injectors
FP Race Manifold
Lightly Built Transmission
Corbeau Seats
Polished Intake Pipe
Get rid of eBay steering wheel and get something nice
Paint Car(Original color, i have been told it is rare)
Move Gauge pod from under stereo to vent where it should be(not sure how to route wires)
7" LCD Screen in place of pioneer deck, connect laptop to it
DYNO TUNE!
I am still looking for all these parts, so if you have 'em, let me know. I most likely wont be getting any of the major stuff done until spring/early summer when i get back home. So far all i have got done to the car is powdercoat some engine parts, so you can take a look at the pics. Would appreciate any input you guys could give. Cant wait to get this thing done!!
Before:
After:
cman3000 is offline   Reply With Quote
