Old 12-04-2008   #1
v8klla
v8klla's Avatar
Unbeatable Pricing on Wiseco Pistons and Eagle Rods from MAPerformance!
Wiseco Features and Highlights
1) Valve pocket designs that allow maximum flow around valve, also allowing oversized valves ang high lift cams to be utilized.
2) Piston crown shapes designed to promote maximum intake charge efficiency thru scavenging mixture "cross flow" during intake and exhaust valve overlap. More fuel and air equals more horsepower!
3) Pistons designed to optimize squish or quench during compression combustion cycle event, resulting in resistance to detonation and pre-ignition. The end product is longer engine life and increased horsepower potential.
4) Complex piston skirt profiles that reduce power robbing friction, yet promote stability in bore for optimum ring seal. Wiseco has added skirt coatings to the long list of standard features on stocked sport compact pistons!
5) Precision machined ring grooves with proper orifice/accumulator volume using calculated groove root diameters and axial widths, featuring excellent surface finish and flatness providing maximum ring seal and minimizes blow-by and oil consumption.
6) World class forging facility that utilizes the latest technologies featuring complex forged shapes, advanced materials, and featured aligned grain flow technology.
Why choose Eagle?
Eagle rods have been performing flawlessly in street and strip motors for years. There proprietary forged H-Beam design is not only one of the strongest designs available, but its one of the lightest also. Being able to rev quickly is the major advantage of this H-Beam rod. Being able to be rated right out of the box to 600 Wheel Horsepower is the Eagle rods killer feature.
Every Eagle rod is heat treated for durability in a racing engine, they are then stress relieved for superior rigidity, and then machined for final fitment and 100% dead on tolerances.
Please contact us for unbeatable pricing on these great products that is simply too low to advertise!
Chris Carey, President
Modern Automotive Performance
P: 763-545-3800
E: chris@maperformance.com
Old 12-04-2008   #2
Shotgun!
Totenritt
Shotgun!'s Avatar
Re: Unbeatable Pricing on Wiseco Pistons and Eagle Rods from MAPerformance!
Can you do anything with the pricing of Eagle cranks?
Old 12-04-2008   #3
v8klla
v8klla's Avatar
For what application? Thanks!
P: 763-545-3800
Old 12-04-2008   #4
Shotgun!
Totenritt
Shotgun!'s Avatar
Chevy Big Block 3.766 Stroke, Thanks!
Old 12-04-2008   #5
v8klla
v8klla's Avatar
How does $639.99 sound for the forged version?
P: 763-545-3800
Old 12-04-2008   #6
Shotgun!
Totenritt
Shotgun!'s Avatar
Sounds great! Let me get back to you in a bit.
