Old 12-09-2008   #1
New Ralliart Dyno Numbers
TTP in Orlando has what might be the first dyno numbers out of the Ralliart. Lucky for them, they've been working with Zeitronics on something called the 'Z-chip' which is some sort of tuning technology for the new CANBUS ecu in the Evo X. The Z-chip seems to work on the Ralliart as well
Keep in mind that this is a quite high reading Mustang Dyno. These guys continually boast big numbers out of Evos with IX turbos in the neighborhood of 430whp. I would expect more in the neighborhood of 380whp max out of that dyno, but it is what it is.
Lower lines are stock, so roughly 190whp/215wtq on DB's Dyno Dynamics dyno, and probably similar numbers to the ones put down on MAP's Dynojet. This car is 100% stock down to the air filter, so an extra 25whp/30wtq is available with a tune, bringing it up to roughly stock Evo IX and X numbers, slightly over stock Evo VIII numbers, but with a small bump in torque. Watch out DSM guys, these numbers are on par with a well put-together pump gas 16g car!
One thing to note is the torque spike and then pull back. They're only running 19psi peak, tapering to like 9psi at 6700rpms. The turbo on it is obviously smaller than the X :P The main drag though is the ecu pulling power (well, torque) due to the SST tranny hitting its max torque rating and closing the throttle plate. I would imagine that a) there is a way around this and b) ecu controlled boost could be used with smaller boost pills to increase boost up top, which would help power significantly.
Anyways, I talked to Brookdale, we won't see these up here till Feb.
I'm sure with some intake mods (the stock intake snorkel is a joke), exhaust,
Old 12-09-2008   #2
hellomynameis
hellomynameis's Avatar
Chinese Checkers Champion! Elite Mahjong Champion!
Drives: Evo IX
Send a message via AIM to hellomynameis
Re: New Ralliart Dyno Numbers
I'd consider upgrading Alyssa to one of these when we need a new car. She doesn't need an Evo but something like this would be perfect. It's just too bad the tuning potential is immediately limited by that transmission and it's electronic throttle cuts.
hellomynameis is offline   Reply With Quote
Old 12-09-2008   #3
razorlab (bryan@gst in cali) has already discovered the mechanism in the ecu that controls this torque cut, so I'm sure it'll be worked around before too long the real trick will be working around it while under power, but keeping the traction control active when you want it.
Old 12-09-2008   #4
rose0529
Who has my man-card?
rose0529's Avatar
Drives: a red car
seems like it should be a fun car with a few mods....
I hear tires are killing it's traction...
Old 12-09-2008   #5
Sweet!
Old 12-10-2008   #6
awd-drifter
'2of9'
awd-drifter's Avatar
Drives: Racer Van V6
not bad. i think it's different route from the Evo X for sure though. I'm pretty sure the ralliart will have pretty decent numbers by summer/fall of 09.
ლ(ಠ益ಠლ)
Old 12-10-2008   #7
Too bad it only comes in SST, I guess Mitsu says the limit of the tranny is 310 ft/lbs of torque. For a mild street car it looks very nice though.
