Old 12-19-2008   #1
Tachyon
Tachyon's Avatar
Drives: Icarus
14b shenanigans
So I finally decided to tune my car a couple of weeks ago to see what my modest 14b setup could do. This is on a 180,000 mile bone stock junkyard engine with the low performance 1990 cams.
Mods:
Rewired Walbro 255HP
Denso 1600cc injectors
Archer Racing exhaust manifold
Custom 3" 1-piece T304 mandrel bent exhaust
3" Downpipe - no idea where it came from
Punishment Racing 14b J-pipe
Ebay 32x24x3 intercooler with 2.5" piping
ACT 2900 6-puck clutch
Fidanza Flywheel
Crushed BOV
Mendards MBC
MegaSquirt I (speed density)
LC-1 WBo2
E-*.*.. whatever shit comes out of the e85 pumps this time of year...
Green numbers were on 17 lbs of boost at 18* of timing advance. The red numbers were on 23 psi and 24* of timing advance (wouldn't make any more power past 24*) AFR's I dialed around 11.5 (on a gas scale)
The TQ output is ok, but they turbo just won't hold boost past about 5000 RPM. It drops to 16 lbs by 6500 RPM. I am not sure if the WG is getting blown open or if the housing just does not flow enough air to retain boost level? I've got a spare 14b exhaust housing that I ported that I might weld the WG shut and see if I can hold boost a little longer...
Fun stuff.
-Sebastian Vettel
Old 12-19-2008   #2
Re: 14b shenanigans
Wow, that's damn good power for a 14b! I'm seriously impressed! WOOT! Slap some HKS 272's on there and see what happens
Old 12-19-2008   #3
2bar1g
Drives: .
Re: 14b shenanigans
I'm not seeing this, but is your car fwd or awd?
2bar1g is offline   Reply With Quote
Old 12-19-2008   #4
Re: 14b shenanigans
Nitrous is about the only thing you could do to make the turbo hold more boost to redline. Good numbers.
Old 12-19-2008   #5
Re: 14b shenanigans
My wife's car made 298whp and 320ft/lbs FWD when she had the 14B on her car. It dropped boost the same and she was shifting pretty low in the RPMs at the track. It didn't have any kind of tuning system on it, we just let 'er buck. It would get some decent knock in 4th gear when the stock MAF would max out. I think Cher made in the 280s when his first DSM was close to stock the 14B. The good old days of running 12s with an exhaust, K&N filter and MBC. Just throw in some 110, crank the boost and hope it doesn't blow up. They do feel decently fast with all that torque.
Old 12-19-2008   #6
iroc_g
Drives: 97 GSX, 95 TSI, 04 Celica TRD
Re: 14b shenanigans
Im impressed. those are damn good numbers, especially with the mileage on that thing. I wonder how long it will last?
iroc_g is offline   Reply With Quote
Old 12-19-2008   #7
Re: 14b shenanigans
Wow, that's crazy power for a 14b!
Old 12-20-2008   #8
Tachyon
Tachyon's Avatar
Drives: Icarus
Re: 14b shenanigans
Thanks for the support guys.
Sorry this is on a an AWD. I suppose it would make a little more in a FWD car. Running at this boost for about 6 weeks and it's starting to kill the turbo... it's got the dentist drill whine now. I knew this was going to happen, but really didn't care because I am building a new engine with a different turbo in about 2 months.
I just wanted to tune it because I was kind of shocked at the kinds of cars the 14b was pulling on.
-Sebastian Vettel
Old 12-20-2008   #9
2bar1g
Drives: .
Re: 14b shenanigans
Dam, I was thinking it was fwd. Very nice numbers
Old 12-21-2008   #10
Re: 14b shenanigans
cool. megasquirt ftw (although I'm buying DSMlink )
Old 12-21-2008   #11
Re: 14b shenanigans
Nice, thats sweet, shim the wastegate out to get some more out of it. lol
Good job.
Old 12-21-2008   #12
Andrew7dg
Built it from scratch!
Andrew7dg's Avatar
Drives: Currently Mitsu-less
Re: 14b shenanigans
Wow now I know there is some hope for my small 16g turbo
Old 12-21-2008   #13
green hornet
Re: 14b shenanigans
hey very nice! hows my old clutch holding up for ya.
FASTER AND FASTER! TILL THE FEAR OF DEATH IS OVER COME BY THE THRILL OF SPEED!!!
Old 12-22-2008   #14
Tachyon
Tachyon's Avatar
Drives: Icarus
Re: 14b shenanigans
Quite good thanks for asking... although now I really have to slip the clutch slowly to avoid wheel spin (need better tires). That and my motor mounts are taking a real beating.
How's the 2g coming along?
-Sebastian Vettel
Old 12-23-2008   #15
wheelhop
Holset's Sex Bitch
wheelhop's Avatar
Drives: 1990 Eclipse, 1991 Eclipse with a little Holset Sex
Re: 14b shenanigans
Slap on a used 7cm^2 turbine housing froma blow 16g or some selling it individually. You'll make more power at the same boost, since you will then have a 16g hotside.
Matt
Bolton Holset H1C w/ external gate, fp2X cams, DSMLink, 3" exhaust, FMIC, water injection
"There is nothing better for man than to eat, drink, and see good for all his hard work." Solomon
wheelhop is offline   Reply With Quote
