Old 12-19-2008   #1
Dundars
Drives: 1g DSM
Upcoming project
Ok so I am in the proccess of finding a good clean 1g shell to slowly start building up over the next year maybe two years... I am in no rush to complete it and relize by then the setup might not be optimal.
However for now the set up plan is gonna go as follows and I'm looking for any input.
HEAD
FP4 Cams
Sl Dual Springs
Ferrea Valve Guides
Port work on Runners and Bowls
Sl Valves / Retainers
ARP Extreme Duty Head Studs
Ceramic Head Coating
ENGINE
2.3 Stroker - Mahle / MAP
Forced Performance "Sleeper" 16g (Hotside Ceramic Coated and Turbo Blanketed)
FIC BlueMax 1450cc Injectors
ETS Ultra Race FMIC Kit with 3" Cold Side
REEF SMIM (Thermal Dispersant)
1g N/T Throttle Body (Thermal Dispersant)
FP Race Manifold (Ceramic Coated)
JMFab Heat Shield
JMFab Tubular o2 Housing (Ceramic Coated)
JMFab Small Battery Kit
JMFab Coolant Overflow
JMFab Dual Catch Cans
JMFab Coil Pack Bracket
SBR Oil Pan
Hallman Boost Controller
Forged BOV
2g MAS
90 Oil Cooler Housing
AMS Oil Cooler Kit
Dual Walbro 255HP
Fuelab AFPR
Fluidyne Radiator (Thermal Dispersant Coating)
Megan Racing 3" Turboback Exhaust with Testpipe (Ceramic Coated Downpipe)
FP 4" Cold Air Intake with Recirc. (DEI Air Tube Cover Kit)
Flex-A-Lite Fans
MSD 8.5mm Plug Wires
BPR7ES Spark Plugs
TUNING
Innovate LC-1 Wideband
DSMLink v2
Prosport Boost / Oil Pressure Gauge
SUSPENSION & DRIVETRAIN
ACT 2600 Clutch
ACT Lightweight Flywheel
KYB AGX Shocks
Eibach Proline Springs
Dundars is offline   Reply With Quote
