Old 03-21-2004   #1
unreal808
Mr. Me Too
unreal808's Avatar
Drives: Suzuki GSXR
Would a load senser be better in place of the TPS for the SAFC? :smoker:
Take her to the limit!
Old 03-21-2004   #2
MustGoFaster
MustGoFaster's Avatar
Drives: A big dirty V8
You mean the good old MAP sensor "hack"?
Old 03-21-2004   #3
1Fst14B
personally, i think with a laggy turbo it may be worth it, but for smaller turbo's im not sure you will see any gains
the theory makes a lot of sence, but i havent heard if its worked out...
adam
Old 03-22-2004   #4
I might try that latter this year, because I have a laggy turbo. What is your set up know?
Old 03-22-2004   #5
SlowWhite
Been there, done that.
SlowWhite's Avatar
For us uneducated can you inform me as to what your talking about?
1997 GSX - new ride
2004 R6 - sold
1992 GSX - sold
1996 GST - sold
1995 GSX - sold
Best 1/4 - 11.7 on 93oct
Best 1/4 MPH - 120mph
Old 03-22-2004   #6
Aren't you running an AEM though?
So, you gonna give us some info on your sig? How much boost? Same old turbo? What dyno? Chart?
Old 03-22-2004   #7
no AEM, I will make a post about it I suppose.
Old 03-22-2004   #8
On the AFC, you normally have it switch from the low throttle to the high throttle map based off of TPS voltage. The TPS sensor is a 0-5volt sensor. Somewhere around .4-.7 volts is usually 0% throttle and 4.5-4.9volt is usually 100% throttle. Most MAP(pressure) sensors also work off of a 0-5volt scale. So the idea is to wire the MAP sensor into the TPS line on the AFC instead of the real TPS sensor. So that it switches from low to high throttle setting from a change in pressure, not just TPS. It might take a lot of fiddeling aroudn with it to get it to work better than the nomrla way, but it could possibly make the time when your building boost more responsive. You probably don't want to throw the biggest MAP sensor on it either since the biggest problem area is more in the low boost range.
