Old 03-23-2004   #1
How wide of a wheels spacer can be used on a 1G w/o having to get new wheel studs? I am looking at both 5 and 15mm.
Old 03-23-2004   #2
Enes
Enes's Avatar
15mm is little too big i think... you should be fine with 5 without having to swap the studs..
-E
Old 03-23-2004   #3
CVD
Sten Sniper
CVD's Avatar
Drives: Evo VIII RS
Send a message via AIM to CVD
I think you want to start looking into wheel studs when you hit about 3/8" of spacer.
And you can do your own damn mm conversion :razz2:
Old 03-23-2004   #4
Enes
Enes's Avatar
9 mm
Old 03-23-2004   #5
Enes
Enes's Avatar
if you really want to be picky
9 mm just under 3/8"
10 mm just over 3/8"
Old 03-23-2004   #6
Once again Enes to the rescue. I am looking at a set of 5/16th. If anyone is wondering, this is to get my brakes to clear my wheels. I am either getting a new set of 17's or going with spacers.
Old 03-23-2004   #7
1QUICK4
Crash Course Racing
1QUICK4's Avatar
Drives: in circles
I run 5/16 spacers so my slicks clear my struts. The stock studs are just barely long enuff. I believe Hyundai Tiburon lug-studs will fit & they are about 1/4" longer.
Old 03-23-2004   #8
Would you drive on the street with the 5/16th spacer? There is also a 7/32nd spacer, but that might be cutting it a lot closer. A piece of cogurated (sp?) cardboard is enough of a spacer for everything to clear and that is measuring about 5/32nd.
Old 03-23-2004   #9
FORSFED
Hey Chris, what wheels are on your car? I'm starting to wonder if I'm going to have the same problem or not.... I have 17" Enkei wheels.
Old 03-23-2004   #10
You'll be fine, I am running 99 GSX wheels.
