Old 01-31-2009   #1
xveganxcowboyx
Wanker
xveganxcowboyx's Avatar
Drives: 95 M3
6 bolt long block
I pulle the engine out of my 91 Talon a little more than a year ago to put in a built one I had around. It had about 140k on it. The compression has been low since I bought it at 115k, but was stable for all those miles. I believe the rings just hit their wear point and will continue that way for some time (so just turn up the boost ) I had a leak down test done which indicated the rings leaking some, but the head leaking relatively little for the mileage. Sorry, I don't have the sheet around any more.
I don't remember everything that is on it. Assume just the basics IE: Oil pan, block with guts, head, and valve cover. There may be brackets or other things, but only count on the things listed above.
I'm asking $400 obo. Must be picked up in Cannon Falls, MN. I don't really have time to transport it. I can be reached on my cell as well as by PM. *removed phone number* -Sean
Last edited by xveganxcowboyx; 06-19-2009 at 02:11 PM.. Reason: Removed Phone Number
