Old 02-08-2009   #1
4g63tcrazy
is Nashty
4g63tcrazy's Avatar
Drives: Cyborg from Japan
Cant install flash player..
Well I just installed Mozilla Firefox but I need to install Adobe flash player to make youtube work. Everytime I try to install it, it says its blocked. Pretty sure I had it installed fine when I used Internet Explorer. I tried installing JavaScript or whatever it is and that didnt help either.
-1990 Mitsubishi Cyborg 4WD-
Old 02-08-2009   #2
x-pride
x-pride's Avatar
Re: Cant install flash player..
Are you logged on with admin rights? If not you will need to install it as an admin. If that is not the case check to make sure you pop up blocker, spyware, anitvirus and Sscript is not blocking the program from installing. By the way you might want to let us know what operating system you are running.
Old 02-08-2009   #3
4g63tcrazy
is Nashty
4g63tcrazy's Avatar
I'm running Vista. I am the admin and it says the user account something.. is blocking it. I have turned off all the firewalls and whatnot and it still blocks it somehow. I will keep trying more ways in a little bit here.
Old 02-08-2009   #4
4g63tcrazy
is Nashty
4g63tcrazy's Avatar
Ok, I dont know what the hell to do.. Those of you using firefox, what program are you using to watch video's? It always tells me to install the Adobe flash player but I can't. Or that Java isn't enabled (Which it is). Even when I turn off all the security crap it still wont let me.
Old 02-08-2009   #5
verify that the date/time of your computer is correct first and foremost. Secondly you can go to http://www.softwarepatch.com/softwar...n-firefox.html and download the stanalone installer.
Old 02-08-2009   #6
4g63tcrazy
is Nashty
4g63tcrazy's Avatar
I've already tried that link. It does the same thing as when I go to Adobe's website. And the date on my computer is correct.
Old 02-08-2009   #7
Try uninstalling firefox completly, reboot, reinstall firefox, then install flash again.
Old 02-08-2009   #8
Also the key to the install is to MAKE ABSOLUTLY SURE. you dont have a firefox window open. Or it will complete without errors but will not actually be installed.
Old 02-08-2009   #9
4g63tcrazy
is Nashty
4g63tcrazy's Avatar
Just did all that. reinstalled it and I get the same thing..
Old 02-08-2009   #10
edit: wrong thread, sorry.
Old 02-08-2009   #11
4g63tcrazy
is Nashty
4g63tcrazy's Avatar
I should probably add that when I use firefox it does work, like I said. But then if I go onto internet explorer I can watch all the videos..
Old 02-10-2009   #12
Download the Flash installer, right click on it and run as Administrator. See if that works. Make sure Firefox is not running at the same time.
Old 02-10-2009   #13
4g63tcrazy
is Nashty
4g63tcrazy's Avatar
Tried it and I still get the same damn thing..
Old 02-10-2009   #14
4g63tcrazy
is Nashty
4g63tcrazy's Avatar
went into administrative controls and turned off all firewalls and still get the same thing..
