Old 03-24-2004   #1
SlowWhite
Been there, done that.
SlowWhite's Avatar
On Sunday the SAFC was installed in Jenny's car, And last night I finally got what I needed to fix the oil leak.
So yesterday I took it for a drive. And I noticed that the RPMS on the SAFC are way off.
basically if I have it set at 4cyl. it sits at "0" rpms till the actual rpms get to about 3500 then it registers 500rpms on the SAFC and won't go any higher
Changed it to 2cyl - it sits at "0" till about 2000 rpms hten it registures 1000rpms. and won't go any higher
Changed it to 1cyl - it registures about 500rpms less then it's actually at. But the catch is it only goes as high as 2000rpms.
the funny thing is say I'm cruising I pull up to about 4000rpms and then let off the gas. Well then the RPMs on SAFC go back to Zero. does this with any of the Cyl settings.
I have to be at atleast 20% throttle for hte RPMS even to register.
It's really hard to explain. We installed it exactly how the Apexi Sit says to install it.
Any idea's? I haven't checked the wires and it was also late when we installed it so it is possible that we got a wire mixed up. But it's been a while since i've used one and I've never actually set one up before. So maybe that's another possibility (that I set it up wrong)
-brian
1997 GSX - new ride
2004 R6 - sold
1992 GSX - sold
1996 GST - sold
1995 GSX - sold
Best 1/4 - 11.7 on 93oct
Best 1/4 MPH - 120mph
