Old 03-27-2004   #1
SquackDiddy
Send a message via AIM to SquackDiddy Send a message via MSN to SquackDiddy
is propane cheaper then nitrous? maybe just to get a lil umph but not to much.
I am on suspension because I refuse to type a decent sentence.
SquackDiddy is offline   Reply With Quote
Old 03-27-2004   #2
BUCKY
Guest
Tournaments Won: 6
Posts: n/a
Its been done. I don't know how well it works or if it is consistant.
Old 03-27-2004   #3
Propane does not give any oomp. It is primarily used to "cool" the engine down and control hot spots that occur in the cyclinder. Im sure there are plenty of FAQ's out there on it. I dont think anyone on this site has ever dealt with it in their car although some might know something more. Correct me if Im wrong...
Old 03-27-2004   #4
jd1828
why dont you just use water injection
Old 03-27-2004   #5
CVD
Sten Sniper
CVD's Avatar
Drives: Evo VIII RS
Send a message via AIM to CVD
There's a much better way to get the same effect as propane without all the fancy propane shit....bigger fuel injectors. Bam, you're done.
It's been tried. It works. It's just more fuel in a different form, big deal.
Old 03-29-2004   #6
Boostin90GSX
Guest
Tournaments Won: 6
Posts: n/a
I thought they only do propane on diesel engines?
Old 03-29-2004   #7
CVD
Sten Sniper
CVD's Avatar
Drives: Evo VIII RS
Nope, but they only SHOULD do propane on diesel engines. It doesnt help nearly as much on normal gasoline engines.
