Old 04-05-2009   #1
Need some advice on Link, can't get car to idle.
Ok.
I just need some advice on what I need to do to get my car even IDLING so I can at least set the base timing and top off coolant, etc
I was too lazy to drain my 1/2 tank of 92 so I setup my global for my injectors on gasoline and deadtime to something reasonable for the injectors. Anyways, I'm sure I have to adjust something in my MAF Comp table but I honestly have no idea what I'm doing. I've tried messing with the airflow table in the 500-600hz range where it idles (GM maf). Nothing really seems to make a difference.
92 awd 6/4. GM maf/cable/ dsmlinkv3, aem wideband, FIC BM 1650, 255hp, 37psi i think, etc.
Old 04-05-2009   #2
Re: Need some advice on Link, can't get car to idle.
The 1650s are probably going to idle like crap on pump anyway. Maybe try some smaller injectors temporarily until you get the airflow settings figured out.
Old 04-05-2009   #3
4seasons69
4seasons69's Avatar
thats kinda wierd. from what I understand link is supposed to come set up so your car will idle. I'm running the gm maf and cable with v3 and my car idles fine with no adjustments. I am only running 950cc injectors though.
but after putting the injectors and link in my car wouldn't idle either and the cause was the pcv hose came off of the intake manifold
Old 04-05-2009   #4
I got the car idling with some help from turbotalon1g and munchgsx. I had to adjust the MAFComp table to like +50%. It's pretty good now.
I know alot of people who have/had 1600cc injectors and their cars idled fine. I'm not too worried about it.
Old 04-05-2009   #5
Looks like these things will be good on pump.
Keep us updated Kevin and please get a full tune on pump incase you ever need it.
