Old 04-06-2009   #1
wants to be sideways...
123abc's Avatar
Drives: Loud cars
Recent Data Log
Hoping I can get some second opinions on how my car is running. This is at 18 psi then falling to 16.
http://www.dsmstyle.com/photopost/data/517/4-4-09.jpg
Originally Posted by Matt D.
Originally Posted by 93GSX5SD
Old 04-06-2009   #2
4g63tcrazy
is Nashty
4g63tcrazy's Avatar
Drives: Cyborg from Japan
Re: Recent Data Log
Looks good to me.
-1990 Mitsubishi Cyborg 4WD-
Old 04-06-2009   #3
munchgsx
munchgsx's Avatar
Drives: 2004 Corvette M6 F45
Re: Recent Data Log
Instead of worrying about wot start tunning fuel trims. Looks to mee like the car is lean.
Old 04-06-2009   #4
123abc's Avatar
Drives: Loud cars
Re: Recent Data Log
So the higher the number the leaner it is? AKA the more the ecu has to richen it up?
Old 04-06-2009   #5
4g63tcrazy
is Nashty
4g63tcrazy's Avatar
Re: Recent Data Log
But he isn't knocking. I'd go as lean as possible til you knock and back up a little. Running pump gas should limit you to around 11.5 a/f max. Which is a good pump a/f.
Old 04-06-2009   #6
123abc's Avatar
Drives: Loud cars
Re: Recent Data Log
I get a 1 random count of knock once in a while but I've narrowed it down to phantom knock, something with the lifters.
Old 04-06-2009   #7
4g63tcrazy
is Nashty
4g63tcrazy's Avatar
Re: Recent Data Log
Yeah it looks good. You could lean it out a little more. If you got a wideband that would really help. I almost learned the hard way!
Old 04-06-2009   #8
123abc's Avatar
Drives: Loud cars
Re: Recent Data Log
I do have a wideband. AEM UEGO. It's between 11 and 10 by redline.
Old 04-06-2009   #9
4g63tcrazy
is Nashty
4g63tcrazy's Avatar
Re: Recent Data Log
11 what and 10 what? Sorry I didn't remember seeing a wideband in there.
Old 04-06-2009   #10
123abc's Avatar
Drives: Loud cars
Re: Recent Data Log
11.6:1 and 10.8:1 afr I should say. I didn't have it installed when you were by. I had the kit sitting in my garage.
Old 04-06-2009   #11
4g63tcrazy
is Nashty
4g63tcrazy's Avatar
Re: Recent Data Log
I'm guessing 11.6 in the mid-low rpm and 10.8 in the upper range? I guess that seems alright since you're just tuning with the maft correct?
Old 04-06-2009   #12
123abc's Avatar
Drives: Loud cars
Re: Recent Data Log
Yup. I gotta figure out a way to record the wideband though. It has a serial output and a 0-5v output as well. I wonder if theres a way to get that to display on the mmcd program on my palm?
Old 04-06-2009   #13
4g63tcrazy
is Nashty
4g63tcrazy's Avatar
Re: Recent Data Log
Not sure.. I haven't heard of anyone doing that with just a palm and mmcd.
Old 04-06-2009   #14
carltalon
carltalon's Avatar
Drives: 98 Eclipse GSX Auto
Re: Recent Data Log
Those timeing numbers scare me. but theres no knock. you definitly need to work on your fuel trims.
11.35 @ 120mph
Old 04-06-2009   #15
4g63tcrazy
is Nashty
4g63tcrazy's Avatar
Re: Recent Data Log
He peaks at 17 degree's of timing wot. What's so bad about that?
Old 04-06-2009   #16
123abc's Avatar
Drives: Loud cars
Re: Recent Data Log
Actually 22 degrees then tapers off at 17. I do need to work on the low trims for sure. I've been trying to get these other little bugs sorted out first before I do 20 pulls on it trying to tune.
But I thank you for the advice, I really do.
Old 04-06-2009   #17
4g63tcrazy
is Nashty
4g63tcrazy's Avatar
Re: Recent Data Log
From my experience and searching 1g's tend to run alot of timing stock.
Old 04-06-2009   #18
Re: Recent Data Log
The stock timing maps are intended for a car running stock low boost though and not leaned out at all. They are usually too aggressive for pump gas and high boost. But every car is different and who knows where his base timing is set at.
Is this car stock injectors? Is that logger really slow? It looks like there are only 2 lines of data for every second.
Old 04-06-2009   #19
4g63tcrazy
is Nashty
4g63tcrazy's Avatar
Re: Recent Data Log
He's on evo 560's
Old 04-06-2009   #20
123abc's Avatar
Drives: Loud cars
Re: Recent Data Log
I'm just working with a palm IIIxe with mmcd and a wideband. And yes, 560's. I do not know what my base timing is set at. I don't have a timing light or access to one so I can't check.
