Old 03-28-2004   #1
fievel
check this out http://cgi.ebay.com/ebaymotors/ws/eBayISAP...6&category=6214
"no blow off valves" funny i see one in the picture. He also mentions that because he is running 24 pounds of boost he sees fuel cut at 5000 rpms. This guy is a douchebag. The part that really makes me cry is that there has been 24 bids on it already.
fievel is offline   Reply With Quote
Old 03-28-2004   #2
CVD
Sten Sniper
CVD's Avatar
Drives: Evo VIII RS
Send a message via AIM to CVD
"This car runs 24psi on a cold day!!!
no blow-off valves
Stage 2 - High Performance Radiator - (This engine never gets warm
Stage 2 - Bauscher racing 2nd gen ported and polished 02 Housing
(-30+20psi) Boost Gauge
2.) Fuel Cut, when running as mutch boost as this turbo puts out, fuel cut happens around 5000rpm, if you want to rev
more, just turn the boost down. Or install SUPER AFC. I have noticed full rpm band with 15-16psi."
hmy:
Old 03-28-2004   #3
Oh my god. $3500! The bov even has jb weld on it. Someone is going to get screwed.
Old 03-28-2004   #4
Jana
Mazda Bitch
"Problem points:
1.) Valve cover has been replaced 3 times! I cannot find a 1st Gen valve cover that doesnt have (MINOR) cracks in it.
Kind of a pain, but does not affect engine performance in any way (All 1st Gen TSi have this problem).
3.) Massive RPS 2800lb clutch, installed to handle the extra HP, but it tends to go through Clutch master and Slave cylinders
every 15k - 20k miles. The clutch requires more weight to disengage because its so big, and the stock clutch cylinders arent built
to supply the neccesary force. They are easy to replace about 1hr, and cost only $40 to rebuild."
maybe he should look for a 2g valve cover, those don't have the same problems as the 1g's do.
He doesn't have any way to control the fuel (SAFC)?? lol
My question is how the hello that dirty car every won Best of Show.....
Old 03-28-2004   #5
-GSX-Falcon
Guest
Tournaments Won: 6
Posts: n/a
What kind of BOV is that anyway? It does not look like a 1g to me. Its at 3,500 and still reserve is not met...kinda sad for a really abused 1G. Ha, he put new fog lights on and didnt take the old ones off....Plus hes running that much boost on a 16G without a FMIC.
Old 03-28-2004   #6
Jacek
Captain J-Sack
5.) Power steering leak. Super slow, the dealership wanted $1800 to replace entire front assembly! I just add steering fluid once every few months.
this looks like a job for jb weld
Old 03-28-2004   #7
4.) Small dent to rear left quarter panel. Very unnoticable, I actually purchased the car 4 yrs ago and only after I bought it did I realize it had the dent.
I was so excited about buying the car that I never saw it! I am not sure how it got there, it was before I owned the vehicle.
Yea I sure cant notice that dent. Its like someone took a toothpick to the side of the car its so unoticable. LOL
Old 03-28-2004   #8
I don't get what the fuss is about? That car doesn't look that bad. Looks better than most of the cars rolling around here.
What JB Weld? I don't see it.
That's a stock 1G BOV.
The lack of AFC is probably saving the car. If he could lean it out so that it didn't fuel cut and run rich then it probably would have blown up by now.
Old 03-28-2004   #9
-GSX-Falcon
Guest
Tournaments Won: 6
Posts: n/a
I guess it could be. Looks like the BOV has a plastic cover on it I have not seen before.
Old 03-28-2004   #10
I see no JB on the BOV. All 1G's came with that plastic cover over the BOV...most have just fallen off or been taken off by now. The kid is full of shit anyways...says it runs 24 psi yet his gauge only goes up to 20.
Old 03-28-2004   #11
Two words: butt dyno
Old 03-28-2004   #12
MATCHBX
Any 2 card caller.
MATCHBX's Avatar
Pinball Smash Up Champion!
I don't see any JB either. The car seems decent. I think he's asking a little much for it (never been much into big audio systems). He may have misrepresented it a little, but maybe he's just trying to make it appeal to more people. Maybe somebody that doesn't know enough about these cars and their engines to understand what he's all saying but sees them around and wants a piece of the action. He might get more than what it's worth, but in the right hands it could be a pretty fast car.
Old 03-28-2004   #13
CVD
Sten Sniper
CVD's Avatar
Drives: Evo VIII RS
At 20+ psi with no fuel mods on a 16G he is absolutely destroying that poor motor. I feel bad for the next owner.
Old 03-28-2004   #14
MATCHBX
Any 2 card caller.
MATCHBX's Avatar
Obviously he started with the fuel pump. I don't want to get into a pissing match over this. I would hope someone that knows something about modding these cars buys this thing to add the few necessary items it will need so it will be up to snuff. It's not too bad of a building block. I think it's a little high priced though. And like I said before, I don't care for the audio part of it. If it were cheaper and closer, I would maybe consider this one to build into a rally car. Take out the audio stuff and sell it to pay for the upgrades for the fuel system. Put a cage in it and away we go!!!!
