Old 04-15-2009   #1
1g and 2g parts fs/ft
1.95 awd tranny came out of a parts car it shifted fine when taken out. has 80k on it.600.00
2. 90 awd tranny. it is all taken apart needs spider gears in it 75.00
3. 4 bolt rear end axels,axel cups and bolts 300.00
4. oem p.p. 10.00
5. 1g intake manifold stock 10.00 have a few
6. Exedy p.p. like a 2600 30.00
7. msd tach adaptor 35.00
8. auto meter 5" tach and shift light 100.00
9. auto meter red warring light new 30.00
10. evo III engine bay harness 75.00
11. evo III engine harness 125.00
12. evo III rs dash and body harness 100.00
13. red 1gb drivers fender 30.00
14. red 1gb pass fender 20.00 needs some work not rusty
15. maroon 1gb pass fender 30.00
16. 2g stock amp 15.00
17. 2g eclipse tails outers 40.00
18. tan spyder plastic panels ask
19. evo 9 rear wheel bearings 25.00 each
20. evo 9 rear knuckles 25.00 each
added 4-23
spyder parts and 2g/7bolt parts all spyder parts have 38k on them
tan leather rear upper seat 50.00
tan rear plastic panels 25.00 ea
tan door stills 10 ea
tan kick panels 5 ea
hood burnt orange scratched up from storage no rust 75.00
trunk lid with gas shocks purple 75.00
tan visors home link 20.00 set
black steering wheel with air bag 100.00
power steering lines 15.00
power steering cooler 15.00
clear front bumper lights 25.00
cruise control 20.00
water pipe 15.00
oil filter housing no cooler on it 10.00
rear block plate for timming cover 5.00
x2 power steering block brackets 10.00 ea
oil pick up 10.00
water pump to alt pully 10.00
alt heat sheild off the evo III 5.00
fuel filter and fuel line to rail 5.00
smic 20.00
black radio bez 15.00
heater core 20.00
fuel rail 20.00
x2 spyder top motors 50.00 ea
clock spring for the air bag and horn 5.00
air bag ecu 25.00
heat/a.c. controls 5.00
oil filter housing compleat 30.00
1g parts and 6 bolt parts
intake mani bracket 5.00
clutch master 5.00
turbo water pipe 90 30.00
turbo water neck lower 10.00
n/a water neck lower 10.00
x2 water neck upper 10.00 ea
cam gears painted red 20.00 set
black w/red strip plug cover 5.00
front awd block mount lower 10.00
x2 rear awd block mount lower 10.00
x2 block timming belt filler panel 10.00 ea
x2 front upper block mount for power steering 10.00 ea
x5 upper block mount 10.00 ea
1ga back up and lic plate wiring and lights 5.00
90 awd shifter bracket for the tranny 10.00 ea
oil pick up 5.00
power steering bracket 5.00
clutch line rubber to slave 5.00
x2 water pump to alt pully 10.00 ea
x2 water pump to power steering pully 5.00 ea
x2 engine lift bracket for ext mani 5.00 ea
engine lift bracket for head to intake mani 5.00
a/c pully and bracket for the belt 5.00
power steering heat shield 5.00
x3 hydro tensioner 15.00 ea
horn 5.00
x5 tension arms 10.00 ea
x3 tension pully 5.00 ea
x3 idler pully 5.00 ea
x2 balance shaft pully 5.00 ea
oil pump gear for t.belt 15.00
x3 b.s. belt gear small ones 5.00 ea
x2 b.s. gear on the crank 5.00 ea
x3 main crank gear for t.belt 20.00 ea
x3 alt arms 5.00 ea
crank spacer plate for inbetween the crank gears 5.00
windshild washer bottle w/motor front 10.00
awd coolant over flow tank 5.00
cup holder 15.00
pwer reg drivers side 10.00
o2 housing 5.00
2din radio bez 5.00
1gb oem side lights 5.00 set
rear washer bottle no motor 5.00
green drivers door handle 10.00
white drivers door handle 10.00
dip stick tube 10.00
battery tie down 5.00
90 fuel rail 20.00
also every one knows I have a ton of other parts just ask and I will look in all the crates to see if I have it and how many I have.
will take a few trades
also have a ton of other parts just ask I have a lot of small parts and some body parts and spyder parts
