Old 04-27-2009   #1
Need broken bolt extracted, Good place to go.
I have a broken bolt in my turbine housing from O2 housing.
Where is a good place I can go to get it done and not have my pants pulled down on the price or time.
Thanks
Aaron
Old 04-27-2009   #2
viridionplague
Re: Need broken bolt extracted, Good place to go.
buy a bolt extracting kit? i got a nice one at home depot for 20 bucks i think, contains a revers threaded head to bore into the bolt and pull it out
Old 04-27-2009   #3
I'd rather not, I don't want to fuck it up.
Old 04-27-2009   #4
viridionplague
i actualy used it on my throttle body shaft bolts, to get the plate off, if its already broken how are you gonna mess it up?
its made for broken or stripped bolts and what not, your call
Old 04-28-2009   #5
Febo
Manic Narcissistic
Febo's Avatar
Drives: IS300
Im sure any local mechanic shop or machinist could get that out for you.
Old 04-28-2009   #6
^Thats what I was getting at.
I just don't have a good drill and I would be more comfortable with someone who has done it a bunch
Old 04-28-2009   #7
I can do it.
Old 04-28-2009   #8
cmspaz
Walls need hugs too
cmspaz's Avatar
I did pretty much every bolt on my front bumper, all but one came out well, the one that didn't was because the I didn't take off the wheel and ended up drilling in on an angle as a result.
Did it the other night to fix my UICP problem, too.
It's really easy, but time consuming. If you can drill a straight hole in wood, you can drill out a bolt.
Originally Posted by Trogdor
Old 04-29-2009   #9
311evo
311evo's Avatar
No not really. I had to bring my turbo to 2 different machinists. The first one broke 2 carbide bits just scratching the surface of those tempered bastards.
The second one finally got it out. 70+ year old guy in cokato, private shop. It's amazing what the old dudes can do with experience, and he was one of the nicest people I've had to deal with, he was uber interested in my car. Took up about half of his day, and he charged me $100. He mentioned he felt bad for charging me so much, but it took him so long. usually hes around $25-$50 for a bolt.
Old 04-29-2009   #10
^thank you for realizing I am not working with some reg. shit bolt, it is a grade 8.8 hardened and I don't have the drill bits.
Either way I got it taken care of and he made it look damn easy with no drilling.
Old 04-29-2009   #11
Nice!
Old 04-29-2009   #12
TwoTalons
Old & Grumpy
TwoTalons's Avatar
Drives: 1992 Eagle Talon TSi AWD
Who did it for you? I'm in the same boat.
TwoTalons is offline   Reply With Quote
Old 04-29-2009   #13
Share with the rest of us where you went in case we are in the same boat at some point.
I would have recommended trying to contact Northern Cylinder Head about 10 minutes from us. They've extracted stuff for me before.
Old 04-29-2009   #14
^no, i'm not sharing.
I went to MAP.
