Old 05-18-2009   #1
ESchwanz
ESchwanz's Avatar
Drives: 97 GSX
Timing belt
How bad & should I be scared of this little chunk , I'm gonna get it fixed ASAP.. or just rubber cement it for now & then do asap....
Grrrr.. wish I was more confident to do it myself.
Chris do you remember what the millage was when you did the timing belt b4?
ESchwanz is offline   Reply With Quote
Old 05-18-2009   #2
Re: Timing belt
I think it could be worse.
But at the same time, I've had a belt fail on me before, and then you're just in a whole new world of hurt that you don't want to get into.
I'd say get that thing changed as soon as you can.
Old 05-18-2009   #3
dumb_ricer
Hates Everything
Drives: Neon
Re: Timing belt
It will *probably* be fine for a while, but I wouldn't risk it for too long if I were you.
The question is, what caused it in the first place?
420A > LS1 > All Else
I > All else
Old 05-18-2009   #4
Re: Timing belt
Tbelt was the first thing I did on that car, along with bshaft elim, new clutch, motor mounts, rewire half of the 6-bolt swap and.....heh yea we could call that 'round 1' LOL!
That was right around 86k miles I think.
Old 05-19-2009   #5
ESchwanz
ESchwanz's Avatar
Drives: 97 GSX
Re: Timing belt
Good Question.. afraid I wont know (or may never know) till I pull it apart or have MAP or someone do it for me.... I wanna try to do it myself, but I'm not very confident on that large of a project alone, but if I did it myself I think i might be able to afford cams....
Thanks! bout time to do it again then I suppose.. I'm at 144K.
Any word on the Kevlar belts.. or just go with OEM??
Old 05-19-2009   #6
Re: Timing belt
OEM. About $60 from Brookdale Mitsu.
I was afraid to do the timing belt as well, but took my time and got it re-assembled in less than 2 hours. Now I wouldn't have a second though about doing it, it was sort of fun learning a new thing too. Maybe have a friend stop by to check the tensioner and that everything lines up right. If you turn it over by hand a few times at least you'll know you aren't going to bend a bunch of valves right away.
Old 05-19-2009   #7
Re: Timing belt
OEM Mitsu belts are good stuff.
Old 05-19-2009   #8
ESchwanz
ESchwanz's Avatar
Drives: 97 GSX
Re: Timing belt
What happened to mine then ... lol j/k I know you don't know...
Old 05-19-2009   #9
awd-drifter
'2of9'
awd-drifter's Avatar
Drives: Racer Van V6
Re: Timing belt
ouch. was your cam cover opened? possible that a smalllll rock could have possibly done that? just throwin it out there..
ლ(ಠ益ಠლ)
Old 05-19-2009   #10
ESchwanz
ESchwanz's Avatar
Drives: 97 GSX
Re: Timing belt
nope never had it open b4... I just happened to open it & stop the motor at the right spot to see it totally on random. lol
