Old 05-19-2009   #1
Constant_Project21
Constant_Project21's Avatar
Drives: E36
Some issues I've ran into.
Hooked my 1g up to a datalogger and went off to do some pulls. Now I thought my car was running really rich, but today when it was hooked up, the duty cycle was normal, the problem was the timing was all over. Like from 17 at idle to 45 at times at WOT..so I'm a newb to any sort of tuning, what's my deal? And how do I fix it? (full mod list in my project thread).
Old 05-19-2009   #2
Re: Some issues I've ran into.
Timing should be all over the place. There is a 16x12 timing map that it uses for a starting point based on RPM vs load.
Old 05-19-2009   #3
Constant_Project21
Drives: E36
Alright, I also have knock, at one time it hit 29, Idk if my crappy Chinese 16g is spooling right, it seems like boost cuts out, it's getting plenty of fuel, but doesn't pull all of the way through. Also there are no boost leaks, just fixed all of them.
Old 05-19-2009   #4
What are your A/F ratios, ignition timing, rpm, and boost when it knocks?
Old 05-19-2009   #5
Constant_Project21
Drives: E36
Rpm=3687, injd=30.4%, knck=26, tps=39.8%, map=2.77 bar, tima=19 degrees, injp=9.9ms. Thats what my data logger read. Boost is stock, just off wastegate.
Old 05-19-2009   #6
Do you have a wideband to read the A/Fs? Why is the TPS at only 39.8%, does it goto 90%+?
Old 05-19-2009   #7
Constant_Project21
Drives: E36
When I got another big spike like that, the numbers were around the same.
Old 05-19-2009   #8
Constant_Project21
Drives: E36
Don't have a wideband, it's on the to buy list. The tps at one time was at 99.6%, at 5093rpms, 70.3% injd, with no knock.
Old 05-19-2009   #9
Does it only knock bad at part throttle?
Old 05-19-2009   #10
viridionplague
sounds like phantom knock to me. at part throttle like that there really isnt any reason for knock as far as im aware
Old 05-19-2009   #11
Constant_Project21
Drives: E36
Yea when it's floored, it doesn't seem to knock.
Old 05-20-2009   #12
Gravy
Who's this guy?
Wideband would shine a whole new light on the issue. I get knock under partial throttle, but my fuel presure is set wrong, i have to adjust way too much for the SAFC compaired to the injectors. Have it set about 4-5psi above stock, and running a 255 on top of it. Figured that out today while watching a movie. Kinda hit me all of a sudden, but without that wideband you don't know what else may be contributing. Maybe your running super lean due to something, or maybe your not.
For an example i got 1 count of knock twice today under partial throttle and with my AF at about 10.0-10.5.
Old 05-20-2009   #13
1-2 counts coming and going is often nothing, just engine noise.
Old 05-20-2009   #14
Constant_Project21
Drives: E36
Yea I get the random little knocks, but there seems to be a running theme with the mid throttle knock around 3000rpm...I gotta get a wideband..
Old 05-20-2009   #15
Gravy
Who's this guy?
I think i finished my gas tune today well enough for now. Tomorrow i'll get some e-85.
Keep it under 3-4 and it's ok, i keep getting the mid range like you are, but it's mostly engine noise.
Old 05-20-2009   #16
twack
It was a auto get over it
twack's Avatar
haha get dsmlink and turn the knock sensor off under 4k
