Old 03-31-2004   #1
93RSLaser
Send a message via AIM to 93RSLaser
has anyone on here put a drift body kit on a 93 laser or at least that body? just wondering if it was a little more diffacult putting it on a laser? if anyone knows please let me know, and give me some hints, another ? was the side skirts, will those fit or what?
93RSLaser is offline   Reply With Quote
Old 03-31-2004   #2
The chasis on all DSMs in the same years... should be all the same. The factory bumpers and spoilers and stuff will be different with each make, eagle, mitsu, plymouth, but where they attach will be the same.
Personally all body kits for 1Gs look gay with exception to the drift front bumper. Which I would only ever use becuase it lets alot more ait flow to the Intercooler.
Personally Id upgrade to the GSX or TSi exterior in your case.
Old 03-31-2004   #3
slowbubblecar
Big Turbo Monster
slowbubblecar's Avatar
Drives: GTS and E55
I put a body kit on my old integra. Depending on the kit and manufacturer, it might be hard to fit onto the car. Some kits just don't fit.
7/25/09
Old 03-31-2004   #4
BUCKY
Guest
Tournaments Won: 6
Posts: n/a
The key is to fit the kit before you paint it. You will have to drill and cut to make it fit unless it is a urathane direct bolt on. Most are fiberglass and when they make them they lay the fiberglass over stock parts and then mold off of that. Because of that they end up just a little bit biger than stock parts. Just remember to take your time otherwise it will look like shit.
