Old 04-01-2004   #1
Jana
Mazda Bitch
I am going to be needing new brakes and possibly calipers. How do I know what is needed (what do I check/look for)?
Also, for the 2G's, what is recommend for a decent set? I don't have a shitload of money to spend, so something in a reasonable range.
Old 04-01-2004   #2
Just curious but why do you think you need calipers? If anything you'll just want to rebuild them which won't cost much.
Since you aren't going to be doing any track action I'd stick with something close to OEM like what you'd find at any auto parts store. If you want a little more stopping power you could upgrade to something like Powerslot rotors and Axxis Metal Master pads.
If you want a complete set of rotors, pads and SS brake lines check this out: http://www.turboimport.com/catalog/promo.htm
These are what I picked up.
Old 04-01-2004   #3
Jana
Mazda Bitch
See, I don't know if I need calipers or not...they look kinda rusty....but I am completely dumb when it comes to the brakes, etc.
Old 04-01-2004   #4
Iceman
I really dout you need new calipers. Just get some brake pads and call it a day.
Old 04-01-2004   #5
They're rusty because they're cast iron and unpainted. If you want you can get them sandblasted and painted which will help prevent them from rusting, and make your car look better. If they aren't leaking or sticking they're fine.
Just get pads and rotors that will suit your needs.
Old 04-01-2004   #6
Your brakes should be fine. Just swap out pads. You should never have to replace the entire unit unless someone is unable to rebuild them due to a corroded marked up piston or cylinder, Or are to lazy to rebuild them. haha
Yes cast Iron rusts.
Old 04-01-2004   #7
We're all forgetting that you need to either resurface the rotors or buy new ones when putting on new pads. If you just slap a set of pads on, they will wear out in half the time since they weren't allowed to "bed in" with the rotors. Resurfacing or "turning" the rotors should be $15-$20 each at auto parts stores that do that, or new rotors are probably about $30 each if you shop around.
I'm sure your calipers are just fine, severely abnormal wear on the pads would tell you if there's a problem with them.
Old 04-02-2004   #8
I would just get new rotors instead of turning them (turning the rotor takes material away therefore they will warp quicker and won't be able to dissapate heat as well). Autozone seems to have the cheapest prices on brake rotors as far as I can tell...but if you are going to get some decent pads you might as well get some decent rotors to go along with that. Summit sells Qualitee rotors which are actually made by Brembo and they are a good quality solid rotor. You could also just go with the ones from Mitsu. The OEM auto part store rotors will warp a lot quicker than the higher quality ones will.
Old 04-02-2004   #9
Depends how much they are actualy worn. They only take off as much is needed. Ive turned my rotors two years ago in the front and 3 years ago in the back and they are no signs of warpage yet.
Stock rotors arent the greatest but they are better then anything from checker or autozone. If your going to upgrade might as well get powerslots.
Old 04-02-2004   #10
illz
eh, what's your logic behind this one? no magic happens that mates the pad and rotor. if the rotor is still flat, unwarped, and the pads are the same size as what was on, you bed in the pads and are fine. hell, even that isn't terribly necessary, but to do it you just bring them up to high temp a few times -- 8-10 60mph to 5mph back-to-back-to-back-to-back stops (never stop completely just get right back up to speed) then drive around and let them cool, repeat with another series of 8-10, done. if you're using a high-temp race pad like a porterfield R4-E , do the same, but make them 100mph to 5mph stops
Old 04-02-2004   #11
LightningGSX
Hellbound
Re-surface and Break-in,"Bedding" ,them in is absolutely neccessary, even if the rotors are flat and non-warped.At least rough up the surface of the rotor, and take it easy during break-in(do NOT do 60-5mph stops).If you just throw them on and do some 60-5 mph stops, you'll glaze the pads 95% of the time, which will lead to increased heat, reduced braking and reduced life of the pads.
-Nulli Secundus-
Old 04-02-2004   #12
LightningGSX
Hellbound
As far as rotors, spend the extra money and get them from the dealer.I've had warping issues with Autozone/Checker rotors everytime, since I have put OEM ones on, no problems
-Nulli Secundus-
Old 04-02-2004   #13
BUCKY
Guest
Tournaments Won: 6
Posts: n/a
If you do decide to get new roters I would have them turned also. When I worked in a shop we would turn all new ones and about 85 % of them were slightly worped.
Old 04-02-2004   #14
Yeah, definately get them turned. Also, I highly recommend the Axxis Ultimate pads. They are way better than the metal masters and only a few bucks more.
Old 04-04-2004   #15
Jana
Mazda Bitch
Thanks for the help everyone! Maybe I was thinking rotors, and not calipers..lol...my bad :uh:
