Old 06-26-2009   #1
hippiekiller
hippiekiller's Avatar
No throttle...
OK, so this is the last problem I have ran into. Car runs PERFECT at idle. Step on the gas and you get nothing, step on it too much and it obviously dies. A couple weeks ago it didn't do this. MAF is plugged in. TPS is plugged in. It is a 1g throttle body on a 2g...Like I said ran, fine before. All of sudden it just doesn't get any gas. I am thinking the problem might be the TPS...Or at least hope so. I am going to double check the tps and make sure that it is where it should be and such, but just looking to see if anybody else has any ideas before I head out to check on it. I know boost leaks, I already checked that and all the vacuum hoses are brand new. Worked perfect before...Now I have no throttle at all. RPMs will not come up, car just dies.
Old 06-26-2009   #2
ESchwanz
ESchwanz's Avatar
Drives: 97 GSX
Re: No throttle...
i'd say ding with the MAF... sounds like its not seeing the air flow.
ESchwanz is offline   Reply With Quote
Old 06-26-2009   #3
hippiekiller
Re: No throttle...
Yeah, that is certainly a possibility as well.
Old 06-26-2009   #4
Re: No throttle...
I say test the TPS with a multimeter and make sure it is positioned correctly, then look into the MAF.
Old 06-26-2009   #5
hippiekiller
Re: No throttle...
Pretty much what I was planning on doing Matt. It is possible the tps got bumped when I was hooking up some of the vacuum lines...I don't think it did, but who knows.
