Old 07-02-2009   #1
bob123131
2g assembled block and front cover 75 dollars spun bearing
Short block comes with rods pistons crank cradle etc and front cover. Has a spun bearing ran fine prior with good compression cylinder walls show signs of a little normal wobble, but no scoring. Also for 105 dollars it will come with the new clutch just installed barely used before spun bearing and awd flywheel still installed.
Its in coates minnesota may be able to meet you.
bob123131 is offline   Reply With Quote
