Old 07-22-2009   #1
daneatsv8s
Drives: 91 Galant VR4, 97 Eclipse GSX, 91 Talon TSI
Apexi Old School SAFC FS
Up for sale today is an old school Apexi SAFC I found inside of my Talon when I bought it. It looks to be in good condition, I have not tested it however. There is some adhesive at the top from the last owner mounting it. The harness has end has been cut by the last owner for reasons I can't imagine. I don't need this because my TSI is running an EPROM ECU with a Keydiver chip compensating for 560cc injectors.
I would like to get 80.00 cash only. Not really looking for trades at the moment.
Send me a PM or give me a call at 612.801.7061.
daneatsv8s is offline   Reply With Quote
Old 07-22-2009   #2
TurboDomestics
TurboDomestics's Avatar
Re: Apexi Old School SAFC FS
bar none the coolest looking mod you can do to any car!
4G63 0, Charlie 3
Old 07-23-2009   #3
daneatsv8s
Bump.
Old 07-23-2009   #4
Constant_Project21
Constant_Project21's Avatar
Drives: E36
I'm gonna do some research on this and let you know. Wouldn't have the first clue on how to use it, so have to find a manual or something.
Old 07-23-2009   #5
4g63tcrazy
is Nashty
4g63tcrazy's Avatar
Drives: Cyborg from Japan
It's very easy to use. Have you ever used an safcI or II? Same thing just knobs pretty much..
-1990 Mitsubishi Cyborg 4WD-
Old 07-23-2009   #6
Constant_Project21
Drives: E36
More or less looking into how to hook it up. Since the harness is cut.
Old 07-25-2009   #7
daneatsv8s
Bump.
Old 07-26-2009   #8
The harness being cut isn't an issue. There is plenty there to make it useable and there wasn't any special connector from the get go. You will just pull the plugs off the ECU (located behind the radio), tap the correct wires and cut and splice the fuel signal wire, mount the controller, and tune.
Bigger issue may be finding the correct wiring diagram for an old unit like that. If I remeber correctly, Apexi had a nice site with instructions on it.
Old 07-26-2009   #9
daneatsv8s
Thanks for the help! Bump.
Old 07-27-2009   #10
daneatsv8s
Bump.
