Old 07-24-2009   #1
95 mirage ls coupe 4g63T
looking to see if anyone wants the car as it sits right now it is still a project car. I am getting way to much complaining from the town house people and the city for working on to many car right now so just going to sell it off now.
Info
vin ja3aa31c5su002560
1995 mirage ls coupe non power
was a 1.8 auto car
it is red
pics and build up http://www.mitsustyle.com/forums/showthread.php?t=20847
The body does have rust like all the other out there. the roof is good. It does have body work on the drivers 1/4 panel that was done not the best. the body filler is cracked. It is all taken apart as of right now the motor is in it. the inside is gutted,but all panels are there still.
93 4g63t 7bolt
new water pump
new timing belt
b.s. elem kit
all new gaskets
new main bearings
new rod bearing
head 1g 7bolt head
new valve seals
94 cams
90 dsm wiring harness and non eprom ecu
90 sensors
evo III exhaust manifold
14b turbo
2g o2 housing
evo 8 fuel pump
dsm 1g peddels
95 mirage shifter and cables
1g fwd turbo tranny
oem clutch
all engine and tranny mounts
custom front to rear brace for the 1g engine and will work for a awd tranny
evo III knuckles with 1g 5lug
2g 2 piston rotors
5 lug rear swap parts
rear disk brake brackets
rear rotors
2.5 in down pipe
2.5 in test pipe
evo III fmic and evo III fmic piping all oem
codan front bumper
90 dsm black and grey front seats
roll stop mounts polly filled
2gb spyder 16in rims 1is cracked and needs to be welded
1g bov
evo 8 brake booster
evo 8 brake master
evo 8 clutch master
a/c removed
p/s removed
needs to be finnished or bought
wiring dsm to mirage have all the extra plugs to make a patch harness
need 2 piston front brakes
need rear dsm calapers
1 rim needs to be welded it is cracked
need injectors 450's or 560 evo's
fuel pump needs to be put in
install rear 5 lug set up
exhaust system made
need 7bolt fwd flywheel
need mas and intake pipe for 2g or I have a pipe for a 1g mas
the car was running when I got it when it was stock with spun rod bearings on the 1.8. I got it to swap and drive last winter just never finnished it. there is more parts than I can remeber that will go with it also.
As it sits right now 1500.00 will take it all
