Old 07-24-2009   #1
slowbubblecar
Big Turbo Monster
slowbubblecar's Avatar
Drives: GTS and E55
Performance parts for sale
**Updated again adding more parts to the list as I will be parting out my 95 GST.**
6 bolt longblock- New copper sprayed hg, rebuilt head, new waterpump and timing. I think the BS was removed at QPR-$550
-95 GST Tranny. Good shape no grinds-$450
-3" apexi thermal exhaust. Goes from 3" V-band off turbo through muffler- offer
-Big greddy FMIC, dented slightly on bottom but doesn't affect performance, powdercoated black I/C pipes- $500 with Greddy BOV or $450 without
-1000 cc injectors- $200 *Pending sale*
-dsmlink V2 and 95 eprom- $500 *Pending sale*
-Act 2600 (possibly 2900)-will inspect when pulled- Offer
-6 bolt fidanze flywheel- Offer
-used walbro 255- offer
-95 copper GST Rolling shell needing motor, tranny, injectors and ecu.
GT35R turbo setup-$1,300
-T3 with 82AR exhaust and 3” V-band exhaust side (turbo is new aside from a few minutes on the dyno)
-New cast T3 manifold setup for a Tial wastegate off the manifold
-3" v-band downpipe made at DB
-All that is needed for the install is a tial wastegate and the turbo lines. I have will give you the FP restrictor for the oil feed line on the turbo.
GT42 Turbo setup (T4)-$1,450
Numbers on the turbo say:
Intake side- 70AR M24 EC-1
exhaust side- .81AR T4 flange, v-band 02 side
-bought it used with around 2,000 on it. Also have a new T4 gasket
-DNP T4 manifold with innovative 44mm wastegate both are used and originally cost $500 each new
-All that is needed are the turbo lines (have part of if not the whole the return line) and the downpipe modification (see 3” downpipe below that could be free)
-3" 02 housing/downpipe for use with turbo V-band (most likely will need modification to connect to catback)-$150 or free with purchase of the GT42 turbo setup.
2g mas with plug- $40
3” chrome intake setup for a 2g mas (no couplers)- $75
New QTP electric exhaust cutout- $165
Aftermarket 2g lower i/c pipe for stock intercooler- $25
3” v-band flange- $10
2.5” 4 bolt exhaust flange- $5
2/3 of a 3” donut (for making 3” 02 housings) probably enough to make 2 more- $60
60mm new auto meter water guage- $35
Autometer Fuel guage (new in box)- $25
Autometer A/F guage- $25
James
7/25/09
