Old 08-01-2009   #1
4seasons69
4seasons69's Avatar
car tuned now it runs like shit?
ok so on thursday I had my car tuned at db and it ran awsome for a day and now it's doing all kinds of crazy stuff sometimes when i give it gas it starts building boost maybe up to 10psi then falls on its ass. then other times it will pull ok and build upto 20psi then feel like it kinda starts cutting out and knocks pretty bad.
I thought I had messed something up in dsmlink when I tried to save the tune to my own computer so I had shane email me the tune but i didn't mess anything up.
I also haven't messed with anything on my car except I tightened the bov spring cause it would blow off at part throttle and my ect sensor the wires on the harness connector broke so I resoldered them but am still having problems with my ect.
could this be from messing with the bov, or the ect being messed up? maybe developed a boost leak? I think I'm just ready to give up on this car. any help will be greatly appreciated. as soon as I figure out how to post a log I will post one
Old 08-01-2009   #2
CVD
Sten Sniper
CVD's Avatar
Drives: Evo VIII RS
Send a message via AIM to CVD
Re: car tuned now it runs like shit?
I'm leaning toward major boost leak.
Old 08-02-2009   #3
twack
It was a auto get over it
twack's Avatar
boost leak test before giving up always
Old 08-02-2009   #4
wants to be sideways...
123abc's Avatar
Drives: Loud cars
If you're on a draw through setup do a boost leak test asap.
Originally Posted by Matt D.
Originally Posted by 93GSX5SD
Old 08-02-2009   #5
Boost leak test, and check your MAF; are all the honeycombs still intact?
Old 08-02-2009   #6
4seasons69
4seasons69's Avatar
alright well i'm up in st.cloud till tomorrow and don't have any tools with me so i'll baby it home and check the maf and do a boost leak test right when I get home
Old 08-02-2009   #7
Make sure the coolant temps are reading correct in Link and they aren't intermittently cutting in and out from correct readings to negative values.
Old 08-02-2009   #8
blackrosenova400
blackrosenova400's Avatar
Good call on that one, ive had that happen before.
Old 08-02-2009   #9
4seasons69
4seasons69's Avatar
that's exactly what has started happening and I just haven't had much time to look into whats causing it. the wires were broken so I resoldered them. and that worked for about thirty miles then it started again so i'll double check those and go from there
Old 08-02-2009   #10
Well if it fixed for a while, I'd say that's it and you just need to replace more of the wires. Cut back until you can find mostly non-corroded wires, then replace them all the way to that sensor. When I disected my 1990 1G harness to modify to fit in my quest, sometimes it was hard to find good wire. Since it's in a hot-ass engine bay for most of it's life it's easy for the wires to become difficult to hold solder.
