Old 08-06-2009   #1
eclipsetuner23
Drives: 95 eclipse gs (n/a)
Question HELP!!!! With the tire rubbing!!
All right so i upgraded from 16" inch stock to 17" inch aftermarket! But in doing so i have problems with my tires rubbing on the wheel well every time i hit a small bump. I do have my car lowered 3" inches from the ground and i have about 150 pounds of speakers and box in back... what do i need to do to stop the rubbing? also in the next two months i want to go to 18"s. So any advice would be great! Thanks in advance
eclipsetuner23 is offline   Reply With Quote
Old 08-06-2009   #2
viridionplague
Re: HELP!!!! With the tire rubbing!!
sounds like you got the wrong sizing for your tires, what size did you use?
Old 08-06-2009   #3
Maybe consider rolling your fenders. I'm in the same boat as my fronts rub to the point where I know have decent sized grooves in my tires.
Old 08-06-2009   #4
Get lower aspect ratio tires, run wheel spacers, roll your fenders, etc.
Old 08-06-2009   #5
A 3" drop? Maybe consider something less. Rolling your fenders will help and probably fix it.
Old 08-06-2009   #6
eclipsetuner23
i want to do the work myself so how do i roll the fenders?
Old 08-06-2009   #7
Rent or buy a fender roller. Start by googling it
Old 08-06-2009   #8
Doesn't Jeff the Alignment Guy rent out his fender roller?
Old 08-06-2009   #9
Yup.
Old 08-06-2009   #10
notsostockgalant
3g camaro owner
Drives: 88' camaro 400hp 327 sbc
If u wish to attempt it at home theres a couple of videos on youtube of how to's
notsostockgalant is offline   Reply With Quote
Old 08-06-2009   #11
ESchwanz
ESchwanz's Avatar
Drives: 97 GSX
Wow that looks pretty simple if you can rent that tool. Hmmm makes me want bigger tires someday maybe.. http://www.dfuser.com/Install%20Guid...structions.pdf
ESchwanz is offline   Reply With Quote
Old 08-06-2009   #12
I have it in my possession right now. Need to return it to him soon.
